counterweight question?
Old Jul 22, 2002 | 09:24 PM
My Junx's Avatar
Rotary Father
Question counterweight question?
Hey guys,
Seems to me all lightweight flywheels need to have a counterweight with them...is this true? Like I have a 9.5 lb flywheel but no counterweight with it and it doesn't work right when the tranny is all back in there. I think if there was a counterweight on the back of the wheel it would set the space right and stuff would work right. Only thing is...I need a weight! Are all the counterweights for lightweight flywheels the same? DO different brands of wheels need different weights? Whats up? I'm not sure what brand my flywheel is but it is on a S5 non turbo. Any help is good help.
Later and thanks
Old Jul 22, 2002 | 09:35 PM
rxseven's Avatar
Special Dark
You need a counterweight from an automatic.
Old Jul 22, 2002 | 10:18 PM
Icemark's Avatar
yes you need a Series 5 counter wieght from an automatic.
The manual tranny cars have it built into the stock flywheel.
Old Jul 22, 2002 | 10:24 PM
whats this about the counter weight? im about to do a conversion on my 90 s5, do i still need to take the counter weight off, or do i leave it with the stock flywheel? i also need help.
Old Jul 22, 2002 | 10:31 PM
Manolis_D's Avatar
what kind of conversion are you doing?... that's a useful piece of information to give the board
Anyway... If you are converting to a manual transmission and are going to use a stock mazda flywheel, then go ahead and remove your <rear> counterweight. If you're using a lightweight flywheel, then you need to get an automatic counterweight to use in conjunction with the flywheel. If you are going from a stock mazda flywheel to a lightweight flywheel, then you need to use the appropriate auto counterweight.
There, I think i got all the possible combinations
Old Jul 22, 2002 | 11:31 PM
darkwaveboi's Avatar
Need donor car in Fairfax
a lot of lightweight flywheels come w/ counterweights too..guess you got gipped
Old Jul 22, 2002 | 11:36 PM
Rpeck's Avatar
What R U thinking self?
ALL lightwieght flywheels are the same size & style (86-91) The only diference is the counterweight. 86-88 & 89-91 use different counterweights. The conter weight is based solely on the weight of the flywheel & the year the car is. You really need to get the counterweight from you flywheel manufacturer... or risk getting one from a "same weight" RB or other flywheel, but it might not be right on.
Old Jul 22, 2002 | 11:40 PM
Barwick's Avatar
SCCA Rookie
you need to have an auto trans counterweight that goes onto the output shaft of the engine (the tapered part), then you bolt the light flywheel onto the counterweight via 6 bolts. From there it's just like normal. At least that's every setup I've ever seen.
Old Jul 23, 2002 | 01:21 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Exclamation ALL lightwieght flywheels are the same size & style (86-91)
Wait. I know the only difference between the lighten steel flywheel for ANY 13B NA 1984-91 application is the same other than the counterweight.
BUT, the diameter of the clutch disc is larger on a T2 than for a NA. I give you the difference really isn't that much. But, as a result, isn't the lightened steel flywheel larger on a T2 application vs NA application?
Old Jul 23, 2002 | 01:31 AM
Icemark's Avatar
Re: ALL lightwieght flywheels are the same size & style (86-91)
yep T2 uses a different size than the NA. It is larger. if your order the Mazdatrix flywheel; it will come with the correct counterweight.
Old Jul 23, 2002 | 01:56 AM
HuggyBear's Avatar
ok guys. iv done the swap to a T2 tranny with a light steel flywheel heres what you need for a lightweight flywheel:
the counterweight from an automatic of the same series. basically this means one thing. the counterweight has to match the total weight of both rotars. thats all. series 4 and series 5 rotars are different weights, thats why u need different counterweights.
the counterweight determined by the engine you have(rotars) not the flywheel, tranny, ect....
BTW i have an 88 counter weight for sale if anyone needs one. good for use on a series 4 car with lightweight flywheel.
Old Jul 23, 2002 | 08:39 AM
banzaitoyota's Avatar
What Subscription?
Did you ever weigh the 2 counterweights?
If not can you weigh the 88? thanks john
Old Jul 23, 2002 | 12:32 PM
My Junx's Avatar
Rotary Father
Yeah I did get ripped off. I bought a flywheel clutch and PP from a guy on here second hand and he failed to include the counterweight, and he will not reply to my messages about it. Anyway, I sure wished I held onto the counterweight that I pulled out of the car when I converted the tranny. I'll go get another and see how it al works.
thanks guys.
Old Jul 23, 2002 | 02:15 PM
My Junx's Avatar
Rotary Father
OK, who has the counterweight that I need? I posted a thread in the parts forum as well, but does anyone here have a S5 auto flywheel counterweight for sale? Let me know.
Old Jul 23, 2002 | 11:21 PM
My Junx's Avatar
Rotary Father
Bump
Old Jul 24, 2002 | 05:05 AM
What Subscription?
I have an extra counterweight, I just don't know which one it is. can some weigh theirs so I can figure this out???
Old Jul 24, 2002 | 10:24 AM
My Junx's Avatar
Rotary Father
OK, I need either a s5 automatic counterweight, or just a plain old stock s5 manual flywheel. Does anybody have their old flywheel around? I'll buy anything to get this biznitch back on the road.
Come on hook me up.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
