Aftermarket wastegates with the twins
Old Feb 11, 2012 | 06:14 PM
Mr rx-7 tt's Avatar
rotary sensei
Anybody using aftermarket wastegates with the twins? Pics and set up...
Old Feb 11, 2012 | 07:59 PM
DaleClark's Avatar
RX-7 Bad Ass
Nope .
Some people have talked about running external wastegates with the twins but no one I know of has succeeded.
That's some SERIOUS fab work to do so, and really with a ported wastegate you typically have decent boost control. That's just a lot of work for not a lot of benefit.
Dale
Old Feb 11, 2012 | 08:36 PM
Mr rx-7 tt's Avatar
rotary sensei
The problem is the stockers seem to be at their limit at around 18 psi so running and holding higher boost is a problem.
Old Feb 11, 2012 | 10:38 PM
cptpain's Avatar
Torqueless Wonder
thats well above the efficiency of the turbos anyway. dangerous without running race gas or a/i
getting BNRs are more efficient at that boost level
Old Feb 12, 2012 | 08:22 AM
DaleClark's Avatar
RX-7 Bad Ass
Yeah, anything above ~14psi on the stock twins and you're just flogging the air and overspinning the turbos. You're also shortening the life expectancy of the twins by a large margin.
If you want more boost, you don't need a new wastegate to do that. Hell, unplug the wastegate hoses and you'll have more boost than you know what to do with. And a blown engine .
Dale
Old Feb 12, 2012 | 05:07 PM
Mr rx-7 tt's Avatar
rotary sensei
They are BNR's.
Old Feb 12, 2012 | 05:11 PM
Mr rx-7 tt's Avatar
rotary sensei
I ran 17-19 psi on the stock twins for almost 10 years. Look at the dyno's of the hp between 14 psi and 17 and there is a difference.
Dale
And that's why you want wastegates that can handle more than 18 psi.
Shainiac
Jul 17, 2019 02:20 PM
sinistersam
Sep 13, 2015 07:17 PM
