OMP line routing
Old Feb 10, 2012 | 06:29 PM
jdonnell's Avatar
OMP line routing
See the picture with the tube going to Oil Injection nozzle with #4 written on it. Can anyone tell me if the tube routing looks correct? I forgot to take a picture there before teardown and it looks too high above the engine?? I fiddled with it but it wants to lay high and sorta interferes with the fuel hose (not in on picture). Thanks (90 NA vert).
Attached Thumbnails OMP line routing-dscn1474.jpg   OMP line routing-dscn1470.jpg
Old Feb 10, 2012 | 07:09 PM
dwb87's Avatar
This is my social media.
I don't think you'll have any issues.
Those new lines look very nice.
Old Feb 10, 2012 | 07:29 PM
PvillKnight7's Avatar
Looks good! I'd split a vacuum hose and push it over the tube where it touches the fuel line. Secure it with 1 or 2 small size zip ties. I do this to all the OMP lines where they're close to the block. I figure it can't hurt if it's not helping...
Old Feb 10, 2012 | 07:31 PM
Are you sure the line is attached to the right outlet on the pump? Is it supposed to be attached to the lower outlet and you have it attached to the upper and that's why it's sitting a little high?
Last edited by PvillKnight7; Feb 10, 2012 at 07:32 PM. Reason: edit quote whatever
Old Feb 10, 2012 | 08:24 PM
dwb87's Avatar
Like we said... Everything should be fine. Can you post a picture of the lines attached to the MOP?
Old Feb 11, 2012 | 06:19 AM
jdonnell's Avatar
Thanks for the inputs. I think I'll take the advice and wrap the lines in vac hose
Attached is the OMP connections. I can't believe I didn't think to attach it to start with.
Old Feb 11, 2012 | 07:09 AM
tuscanidream's Avatar
T2 Duo!
Where's your original hose? Both mine and my girls OG hose is somewhat stiff so routing is literally "lay it on top of the engine".
Ps on the omp- bottom right is oriented incorrectly. All lines there point upward.
Old Feb 11, 2012 | 07:13 AM
T2 Duo!
I'll see if I can get a pic of one for you.
Old Feb 11, 2012 | 07:30 AM
jdonnell's Avatar
Yeah, I'd appreciate a pic of your OMP and top of engine.
My original tubing I still have.
Old Feb 11, 2012 | 07:40 AM
T2 Duo!
I don't have a complete keg to lay it on, but you should be able to see from the pictures. OG lines hold all the bends, so you literally just place it on top of the keg. Use your old ones as a guide. Were your old lines broken?
Edit: these are for s4 t2. I just realized you were s5 na. You might want to make sure they are the same.
Old Feb 11, 2012 | 08:24 AM
dwb87's Avatar
Look fine to me... S5 N/A MOP line routing:
Old Feb 11, 2012 | 09:13 AM
jdonnell's Avatar
tuscanidream, I think your lines are from an S4 so they are a little different from the S5. My dumbass removed the lines before removing the OMP. Wish I would've thought of removing it as an assembly.
Thanks dwb87! Boy that's clean!
I thought of another question? How do you prime these? If you break in the engine how does the apex seals get lubricated at low rpms? If memeory serves, I think the OMP doesn't pump until 2000 rpm, or something like that.
Old Feb 11, 2012 | 09:37 AM
dwb87's Avatar
That's not a picture of my engine above. ^
Unplug the leading coil and temporarily remove the spark plug wires. Crank three times, ten seconds at a time. This will prime the oil system. Be sure to verify that you have oil pressure.
Old Feb 11, 2012 | 12:57 PM
jdonnell's Avatar
I will as soon as I get my car back from the paint shop.
Old Feb 12, 2012 | 01:11 AM
fcs4manila's Avatar
S4 Love
nice job
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
