Low compression on '87
Old Feb 10, 2012 | 04:12 PM
Jaybleezie's Avatar
Unhappy Low compression on '87
I ran a compression test and all of the pulses were even at about 95. What im trying to figure out is what SHOULD the compression be? Also if you have any diagnostics as to why im getting even pulses at 95 would be appreciated. Thanks
Old Feb 12, 2012 | 03:08 AM
7speed's Avatar
bcrotary.
95's still considered healthy. So, once you get into the 80's, start saving for your rebuild kit.
You are not looking for excellent numbers, just three even bounces above 70 PSI.
From: http://www.banzai-racing.com/compression_test.htm
3 even bounces of 85 PSI or above is GOOD. Readings above 110 PSI is GREAT!
3 even bounces of less than 85 PSI: indicates that motor is tired, and indicates engine should be rebuilt before causing damage to rotors or rotor housings.
Old Feb 13, 2012 | 02:21 PM
RotaryRocket88's Avatar
Top Down, Boost Up
95 psi is good. The minium spec in the FSM is ~82 psi IIRC.
Old Feb 18, 2012 | 04:45 PM
RotorHappy's Avatar
85 psi @250 rpm...and max permissible difference between chambers is 21 psi
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
