just hooked up an MSD 6al box, Now the tach dosent work???? help!
Old Feb 10, 2012 | 12:29 PM
ziggybro's Avatar
FL just hooked up an MSD 6al box, Now the tach dosent work???? help!
i just installed an MSD 6al box and after re wireing the leading coil. i have no tach..
like when i start the car it jumps like it normally does. but then returns to 0 like its
getting no signal.... i know the MSD 6al box has a tach output plug in slot on the
side, i think its for aftermarket tachs, but im trying to figure out if this can be / needs
to be hooked to the old tach wire and which wire is it? i wanted to try and figure this
out before i tear the dash apart and trying to trace the tach wire....
this is a 1980 first gen rx7... im trying to go out to the track tonight plzzz help???
sucks raceing with out a tach lol
Old Feb 10, 2012 | 01:21 PM
gsl-se addict's Avatar
Super Moderator
It should work. If you have an '80, the tach wire should have come off the old leading coil (-). After '80, they took the signal off of trailing.
Are you getting spark on leading. I assume that you are, but I thought that we should check spark before checking the wiring.
streetlegal?
Mar 17, 2022 02:46 PM
astrum
24
Nov 15, 2017 08:44 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
