Anyone using a Rotary Works Aluminum rad?
Old Feb 9, 2012 | 11:36 AM
R.P.M.'s Avatar
Likes to swear....alot
Looking at their aluminum rad for the RX2. It seems like a good price for a 4 pass rad.
Anyone using one now? Does it fit well?
Need to upgrade my stock rad, overheated my 13B half bridge last time I had it running.
Old Feb 9, 2012 | 08:16 PM
turbo_dave's Avatar
#turbodavebuilt
We used it on a friends rx2,mounting holes are slightly off but no big deal.
Old Feb 9, 2012 | 10:33 PM
Siraniko's Avatar
RX for fun
RW aluminum radiator is good choice as it is similar to stocker and since rad will sit below the radiator support, that will give you lots of space between the motor and radiator, it means, lots of choices for E-fan. I shopped around for a few weeks and decided not to buy the RX-4/SA/FB style radiator due to space issue. Not installed yet as Rene @ RMS made a slight adjustment to the side mounts per my request. I'm using a junkyard special fiero fan on mine.
Dave,
You must love to run your oil very hot...no fan on your oil cooler. LA summer and stop & go traffic is a killer
Old Feb 9, 2012 | 11:27 PM
turbo_dave's Avatar
#turbodavebuilt
^the scirrocco dual fans not big enough to cover them.the oil cooler is angled a bit so it can clear the front valance,but we are going to install some mini fans on it.stop and go traffic lol wacky we go full throttle around it lol.
Old Feb 9, 2012 | 11:37 PM
turbo_dave's Avatar
#turbodavebuilt
Wacky I know the rx3 style radiator does sit and goes in below the radiaotor support but the rx2 mounts a little differently too.here's an example of the RW rx3 style on miles rx3.I always angle the oil coolers so I won't have to cut up the front valance and it also won't look ugly from the front of the car sticking past below the valance.I forgot to mention that the oil coolers are from rotary works also.
Old Feb 10, 2012 | 10:25 AM
R.P.M.'s Avatar
Cool, you mention those are VW fans your using?
Old Feb 10, 2012 | 09:53 PM
turbo_dave's Avatar
#turbodavebuilt
Yes they are from summitracing.com.they are for the scirrocco style radiator.
Old Feb 10, 2012 | 11:29 PM
cfamilyfix's Avatar
is this the same one...
http://www.summitracing.com/parts/FLX-365/
Old Feb 11, 2012 | 09:40 AM
turbo_dave's Avatar
#turbodavebuilt
Yupp...those are the ones.those fans are real strong and we have no problem we overheating.we installed a 190 fan temp switch so they turn on at around 190 and shut off at 175.thermostat installed is 170.
Old Feb 11, 2012 | 11:35 AM
AuthoritySucks's Avatar
RollinRock
Dave's the man!
Old Feb 11, 2012 | 12:49 PM
Siraniko's Avatar
RX for fun
Here's my newly installed RW aluminum radiator with fiero fan with approx 2M CFM of air at a junkyard price of $15. Covers the entire radiator and oil cooler. I have good experience with fiero fans and it doesnt eat too much amps at start-up like the larger ford taurus fan, approx 1.5" clearance between the main engine pulley and the fan motor. I just need to get new hoses now as this is an upgrade from a RX-2 stock radiator
Old Feb 11, 2012 | 01:02 PM
Siraniko's Avatar
RX for fun
Wish I can fly thru downtown LA during rush hour traffic
Old Feb 11, 2012 | 10:44 PM
orange advan's Avatar
just bought one of these, haven't installed it yet. the quality really isn't all impressive. but not a big deal as long it works.
Old May 22, 2012 | 08:49 AM
Siraniko's Avatar
RX for fun
Just an observation, drove my RX-3 to WHIV in vegas this past weekend. Coming back to Socal, my temp never passed 205* despite it was over 90* around noon. My speedo was out but i was constantly above 6k rpm as i was flying through uphill say after CA/NV stateline. Not bad for the price but it could be better. My mechanical temp gauge is mounted behind water pump housing so it read outlet temp. Rate maybe 7 out of 10
Old May 27, 2012 | 03:45 PM
mazda1200's Avatar
I have one and work fine..
immanuel__7
89
Sep 5, 2015 10:23 AM
