What did I mess up?
Old Feb 9, 2012 | 12:31 AM
fcs4manila's Avatar
S4 Love
What did I mess up?
1987 T2
89,xxx miles
I noticed this problem after I removed my airpump and ACV and added the cover plate.
It may not be the cause but here's what happened.
My low end torque went down. I do still feel it being torquy after 4k RPM.
And when I'm inside my car, I hear a resonating high pitch sound once in a while coming from the passenger side of the engine. Sometimes it's there sometimes it's not.
It's like my car lost power.. I'm not feeling like it launches like it used to do.
Old Feb 9, 2012 | 01:17 AM
philvia's Avatar
sounds like you have a boost leak.
Did you use silicone or a gasket with that block off plate?
Old Feb 9, 2012 | 09:21 AM
fcs4manila's Avatar
S4 Love
I used a gasket.
Old Feb 9, 2012 | 10:40 AM
RXSpeed16's Avatar
Theoretical Tinkerer
Check the vacuum line that feeds the twin-scroll actuator. It's the canister attached to a linkage on the turbo manifold and has a hardline going towards the rear of the engine.
Old Feb 10, 2012 | 07:15 PM
fcs4manila's Avatar
S4 Love
I'll check it out. But I'm not sure about it if it's causing my problem. I feel like it has something to do with the ACV cover plate or something on the UIM.
There' were metal pipes connecting to the ACV, does boost leaks happen there if its not covered?
Sethix
Nov 3, 2017 11:48 PM
Robrods64
Oct 2, 2015 07:56 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
risingsunroof82
22
Sep 22, 2015 01:20 PM
sherff
Sep 12, 2015 12:22 PM
