e-shaft pulley replacement on a s4 automatic?
Old Feb 7, 2012 | 09:10 PM
Slade Gunar's Avatar
~924 Drifter~ fc n0000b
been wondering about this for awhile now and was curious if anyone has had any actual experience doing this.
ive read alot of other threads about removing the crank/e-shaft pulley and i know your supposed to keep the clutch depressed the whole time when you remove/install a pulley if the engine is still in the car to prevent a bearing from slipping and getting crushed behind the front cover.(yeah i forgot what its called exactly its been awhile)
my question is what is the proper procedure on a automatic since we dont have a clutch and instead have a flexplate bolted to a torque converter. is it going to cause the same thing to happen with the bearing on the shaft because of the weight of the converter on the back of the e-shaft?
Old Feb 7, 2012 | 09:28 PM
gerald m's Avatar
Dragons' Breath
Is this a trick question
Old Feb 7, 2012 | 09:31 PM
rxspeed7's Avatar
F-IT
Take off the inspection cover and with a prybar have someone pry the torque converter towards the front of the csr
Old Feb 7, 2012 | 10:23 PM
misterstyx69's Avatar
Retired Moderator, RIP
the pulley comes off with 4 screws..The hub is the one with that 19mm.Pulley attaches to hub.
Now if you are taking the hub off too,then get the bolt loosened then put the car in neutral.
Old Feb 8, 2012 | 12:23 AM
the hub is what i am going to remove with the starter trick. the 2 pulleys for the ac and p/s im not using. i already removed them from my stock hub. i should of said hub in the first place. im just afraid of ruining my thrust bearing when i remove the bolt and put the new pulley on. every other one i read about was on a stick car. i was just curious if someone had actual experience doing this on a automatic without the biased opinions and hate that people kick up whenever the automatic topic comes up
Old Feb 8, 2012 | 01:36 AM
rx7_FREAKKK's Avatar
They live We sleep
Is he talking about the Flex plate?
Old Feb 8, 2012 | 02:00 AM
They live We sleep
I been working on cars since 1988. I did an auto to manual swap with my 7. And i still dont know what an Eshaft Pully is.. Unless you are talking about the Front where the Belts are.
Old Feb 8, 2012 | 02:30 AM
the pulley, the hub. rotarys dont use a crankshaft so its not really a crank pulley..... eccentric shaft hub and pulley.
Old Feb 8, 2012 | 02:42 AM
rxspeed7's Avatar
F-IT
You can remove the pulleys all day without an issue, but once you remove the hub someone needs to have a pry bar on the flex plate pushing it towards the front of the car. No need for useless post this is end all info needed for the removal of the front pulleys and hub.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Apoc3D
Sep 5, 2015 10:24 AM
