Part number help
Old Feb 1, 2012 | 06:37 PM
The Laser's Avatar
Part number help
I'm having trouble finding a part number due to me not knowing what the actual part is called. It's at the base of the shifter and is a rubber seal that helps keep out the road noise and water/moisture. If someone could tell me what this part is actually called, that would help immensely. I found it not too long ago but can't remember where and I DID use the search to try and find it but a lot of it was irrelevant stuff. Again, thank you for the correct answer in advance.
Old Feb 2, 2012 | 04:35 AM
dwb87's Avatar
This is my social media.
The inner boot. Part number: 17-480A-M513
Mazda Trix sells them. (About half way down the page.) -> http://mazdatrix.com/g4.htm
Old Feb 2, 2012 | 10:47 AM
Elgonidas's Avatar
Lightbulb
Also, if you sign up at http://allmazda.net/, you get easy access to the mazda EPC.
Old Feb 2, 2012 | 11:18 AM
The Laser's Avatar
Awesome, thanks for the quick replies guys.
Old Feb 2, 2012 | 11:20 AM
The Laser's Avatar
And I also feel stupid now, since I'm sure it was mazda trix that I saw them in >_< now another site for bookmarking lol
Old Feb 3, 2012 | 12:05 PM
The Laser's Avatar
Alright, another dumb question. What exactly does the middle boot do. I was looking through the Mazda trix site and saw it and have no clue where exactly it would go.
Old Feb 3, 2012 | 12:32 PM
ace626's Avatar
There's a couple of rubber boots that interlock to separate the cabin from the outside. The part in post 2 seals where the shifter enters the transmission
This part (middle boot) seals the cabin from the outside. One boot bolts to the car on its four corners and the other boots interlock with it and seal around the shifter
http://www.mazdatrix.com/pictures/G-...490B-FD01B.jpg
Old Feb 3, 2012 | 01:04 PM
The Laser's Avatar
Ahhh, ok. Now that you say that, I think that's the one I need lol. I'll double check when I get home. Thanks again.
diabolical1
30
Jan 30, 2016 05:50 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
