Electrical issue
Old Feb 1, 2012 | 03:56 PM
phound69's Avatar
OR Electrical issue
87 n/a
152k
Was running, but started sputtering a while back - would cavitate, eventually topping out at 4k. Now has problems starting, won't run.
Battery fully charged
Tested cas - in tolerances
Coil getting 0 volts when testing b/y and ground at connector, yet going across was getting -12 volts, key on both attempts.
No spark on leading or trailing.
Old Feb 1, 2012 | 04:16 PM
satch's Avatar
Originally Posted by phound69
87 n/a
152k
Coil getting 0 volts when testing b/y and ground at connector, yet going across was getting -12 volts, key on both attempts.No spark on leading or trailing.
What does this mean? There is no ground wire at the coil or am I misunderstanding you?
firzen
Sep 15, 2015 12:04 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
rotor_veux
Sep 3, 2015 07:10 PM
