will running straight pipe blow the motor?
Old Jan 30, 2012 | 12:57 AM
beachFC's Avatar
Bridge Burner.
i bought an N/A s5 recently with full headerback straight piped exhaust, with the O2 sensor unhooked, i read something about someone blowing their motor due to the straight pipe not having enough back pressure and i guess it was running too lean or something like that? i'm not sure, but i really wouldn't like to blow my motor.. and i've never heard of this happening until i read that thread.. i was wondering if hooking up O2 sensor(because mpg) would maybe make it run lean and blow? what do you think?
Old Jan 30, 2012 | 02:13 AM
jerd_hambone's Avatar
Turbo engines with no exhaust and a fuel cut defencer run to lean and blow.
With an NA, no worries. If someone claims that, they aren't very bright and probably did something else wrong.
Old Jan 30, 2012 | 02:29 AM
rx7_FREAKKK's Avatar
They live We sleep
Im running straight pipe. But runs better with at least a good exhaust. Seem to have better power with at least 0.50lbs of back pressure
Old Jan 30, 2012 | 03:31 AM
need RX7's Avatar
Listen to King Diamond.
Not on an S5 n/a, but you will **** off yourself and everyone around you. Don't do it.
Old Jan 30, 2012 | 07:34 AM
FC13BSp20F's Avatar
Rotard o_O
So your pretty much saying if you have a FCD with a downpipe and exhaust it will blow the engine? thats not what I hear
Old Jan 30, 2012 | 07:38 AM
texFCturboII's Avatar
version 2.0
Well ya heard wrong. Or msiread.
Old Jan 30, 2012 | 07:40 AM
RRTEC's Avatar
Rotartist
Hrm... I have a Turbo motor, 3" catless N1 Style exhaust from front to back.. FCD built in to ECU. I had not heard that this was a recipe for exploding apex seals...
So Do I need to add a boost controller?
Old Jan 30, 2012 | 08:13 AM
Silver Comet's Avatar
Nick
This is only for the turbo engines not N/a. I believe that your in the clear.
Old Jan 30, 2012 | 10:16 AM
jackhild59's Avatar
Rotary $ > AMG $
The only thing you will blow is your eardrums..
Old Jan 30, 2012 | 10:57 AM
Nick
Lol
Old Jan 30, 2012 | 12:23 PM
version 2.0
that would help, but more fuel would be a plus as well
Old Jan 30, 2012 | 12:30 PM
RXSpeed16's Avatar
Theoretical Tinkerer
Did you conveniently leave out a ported wastegate?
Old Jan 30, 2012 | 01:00 PM
j9fd3s's Avatar
Community Builder
i noticed this too. my S5 feels like it makes more power with the cats vs straight pipe under 4500rpm.
however its not because it wants backpressure, but i think because the stock ecu tune doesn't work very well @wot under 4500rpm with the straight pipe* if you tuned the ecu with the straight pipe it would make more power.
as for blowing the engine, the S5 NA runs so rich that its fine, if anything it runs a little richer when its opened up.
*going WOT, it feels like it makes noise, but doesn't go anywhere, so its either too lean, or its too rich and not enough timing or something, i didn't check. it was also too loud and too stinky so i put the cat back on it....
Old Jan 30, 2012 | 01:57 PM
They live We sleep
My car stinks Bad. I mean Just backing into the garage and shutting car off smells up the house. I never have a tailgater. I am always looking in my rear view to make sure no cop is smelling my exhaust. Cause that could be bad. Its funny though I will get a tailgater very rarely then after 5 seconds they back off and then go around. they never hang out
Old Jan 30, 2012 | 04:00 PM
RexRyder's Avatar
What? 5 seconds??? Get 2 step now nobody does it. Hahaha
Old Jan 30, 2012 | 04:40 PM
SpeedOfLife's Avatar
rotors excite me
It will be deafening. You'll hate yourself for doing it after a week or so.
Old Jan 30, 2012 | 05:41 PM
j9fd3s's Avatar
Community Builder
yes, burning gasoline smells. since the rotary engine emits more unburned hydrocarbons than a normal piston engine, it will smell like its rich, even if its not.
Old Jan 30, 2012 | 07:25 PM
Too much boost, not enough fuel. If you have the supporting mods, it would be acceptable. An FCD just tricks the stock ECU into thinking it is running less boost than it actually is.
If your ECU has one built in, I'm assuming an Rtek, then you have some way to control the fuel. So you're in the clear.
Old Jan 30, 2012 | 07:28 PM
sbrmechanic's Avatar
I was thinking about headers on my n/a fc3s but i also heard that it can be bad for the engine? dont know who to believe
Old Jan 30, 2012 | 07:29 PM
nycgps's Avatar
PedoBear
A straight pipe makes ur car smells like ****, thats the biggest reason why i sold the full rb set that came with the car.
Old Jan 30, 2012 | 11:56 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you have a good pair of mufflers (ie stock or RB), the sound levels can be semi-tolerable with a straight pipe alone, but the highway drone gets annoying. Toss in a header, and all bets are off.
A full RB exhaust does not use a straight pipe. It'll have a presilencer, which is not at all the same.
No.
Where the heck do these rumors come from?
Old Jan 31, 2012 | 01:13 AM
nycgps's Avatar
PedoBear
Well, just saying i cant stand anything without a cat ... it smells bad. :-)
Old Jan 31, 2012 | 01:33 AM
I had a true dual header to two glass packs and a set of FlowMasters. Never got any smell.
Old Jan 31, 2012 | 01:51 AM
beachFC's Avatar
Bridge Burner.
well i have an sdj header(gangster) straight, and i mean STRAIGHT *** pipe from that to a RB muffler.. i was just wondering if connecting the O2 sensor would hurt.. thanks.
and F*CK yes its annoying driving more than 1 mile at a steady rpm.. it almost puts me to sleep sometimes driving 15 miles to/from work.. its like a loud humming lullaby hahaha
Old Jan 31, 2012 | 11:06 AM
i feel like a noob for asking but are headers hard to install?, i can imagine the bolts would be a bitch to get off from getting so hot
