13b-re vs. 13b-rew waterpump
Old Jan 26, 2012 | 10:39 AM
wankelgrandfather's Avatar
An artist
I'd like to know if the 13b-rew waterpump is the same than a 13b-re waterpump, because I am looking at an upgraded waterpump that could fit my 13b-re set-up.
That info would be greatly appreciated.
Old Jan 26, 2012 | 05:08 PM
DaleClark's Avatar
RX-7 Bad Ass
I *THINK* the RE uses a water pump setup closer to the FC. If so, it wouldn't work.
The 13B-REW water pump turns backwards to previous RX-7 water pumps. The back of the alternator/airpump/water pump belt turns the water pump. In the FC, the main part of the belt engages the water pump.
Dale
Old Jan 26, 2012 | 08:58 PM
Ball joint's Avatar
Turbo Lover
Won't work. RE pump turns the other direction. You'd need to swap the entire front cover and everything that goes with it.
If you're looking for a better water pump buy the Mazmart water pump. It's a much better design and won't cavitate at high rpm like the stock one. If you do install the Mazmart pump don't install a underdrive pulley on it.
Old Jan 27, 2012 | 06:24 AM
Banzai-Racing's Avatar
Rotary Specialists
The pump itself cannot be swapped, however if you change out the pump and housing assembly you can install the FC or FD. For either setup the pulleys need to be reconfigured.
We have the S4 FC water pump on our 13b-Re and the FD water pump on our 20B, which uses a similar setup to the 13b-re
Old Jan 27, 2012 | 08:17 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
Do you happen to have any close up pics of how the fuel lines are run on the white 13B RE?
Old Jan 27, 2012 | 09:51 AM
An artist
That's exactly what I want to do, and why I asked if it would fit. I want to keep the FC A/C so will it be possible with either water pump set-up?
So I don't have to change the front cover? I just need to find a complete FD water pump with it's housing assembly?
Old Jan 27, 2012 | 10:06 AM
Rotary Specialists
The front cover does not need to be changed. Both engines above have the FC/Cosmo style CAS.
GKW
Sep 28, 2015 04:34 PM
