85 RX7 parked for 10 years
Old Jan 23, 2012 | 10:45 PM
chrishale's Avatar
SC 85 RX7 parked for 10 years
I have a 1985 mazda rx7 thats been parked for 10 years that I would like to get going.Put a new bat in it the clutch is stock down but then engine will not turn over.When we pulled it to the workshop the tires just dragged.I beleive the engine is locked up any ideas?
Thanks
Chris
Old Jan 25, 2012 | 08:41 AM
gsl-se addict's Avatar
Super Moderator
If you had the car in neutral and the wheels were dragging, it is probably the parking brake is seized up (rear brakes). For the engine not turning over, you will need to tell us more. Is the starter trying to turn it over, but can't? Can you put a socket on the front engine pulley and turn the engine over by hand (remember to put transmission in neutral)?
The engine could be seized ue to carbon buildup, but there are some methods for working it free. However, it seems like you may have more than one thing going on here. We will need more info to figure it out, though.
Kent
Old Jan 25, 2012 | 07:21 PM
chrishale's Avatar
No the wheels will turn if in neutrel it was in gear.Ill have to try turning the engine by hand but yeah you can hear the starter engage but wont turn the engine
Old Jan 26, 2012 | 01:29 AM
iowan82's Avatar
i almost bought an rx7 a few years back with the same exact problem but that was in iowa it was a hot little car tho! good luck! hope it works out for ya!
Old Jan 26, 2012 | 10:02 AM
Shade Tree's Avatar
Sounds like it is carbon locked. The one I just bought was the same way. Do a search on carbon locked on this forum and it will tell you what to do. I used MMO on mine and it worked.
Old Jan 26, 2012 | 10:13 AM
rxtasy3's Avatar
yeah it could be carbon. it could also be seized bearings.
Azevedo
26
Mar 1, 2019 09:19 PM
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
