Supercharger /Turbocharger
Old Jul 22, 2002 | 12:54 AM
zaridar's Avatar
35r 13b first gen
Could someone please tell me the difference between a supercharger and a turbocharger?
Thanks!
Old Jul 22, 2002 | 09:00 AM
Project84's Avatar
Open up! Search Warrant!
Click on this link to learn the difference between a turbocharger and a supercharger.
http://www.howstuffworks.com/question122.htm
Old Jul 22, 2002 | 06:04 PM
85RX7GS's Avatar
Turbocharger uses the engines power to work, usually at high rpms and the supercharger has it's own power source, ie, not the engine.
Old Jul 22, 2002 | 08:10 PM
moremazda's Avatar
Gone Race'n
900+ posts and you answer with this!!!! You must hang out in the lounge alot!!!!
A turbo uses exhaust energy (ie heat and air flow) to spin a turbine wheel. This turbine wheel is attached to a compressor wheel through a shaft. This shaft is either supported buy engine oil pressure (like and engine bearing) or a ball bearing like the ones on skate board wheels. This compressor wheel draws air in compresses it and the forces the air into the engine. It is not uncomon for turbo to spin 70,000-90,000 rpm, even more.
There are two different types of supercharges one is called a roots blower and the other a centrifugal supercharger.
A roots blower mounts on top of the eninge between the air/fuel induction (ie Carb) and the motor. This type of supercharger uses two impellers to generate a vacume resemebeling a larger displacment engine. If you were the carb on a 350 chevy (for example) you would think you were sitting on a big block. These are the ones you see sticking out of the hoods of old muscel cars.
A centrifugal supercharger is basicly the compressor side of a turbo, drive through a geared reduction off of the engines crank shaft.
Supercharges are limited in their rpm cappacity since they are directly coupled to the engine. Therefor thier abbility to produce monsterous top end power is limited
How-ever they are much more benifical in boost response, low rpm and midrange power since there is no waiting for the device to speed up to start moving air, they move a specific amount of air for a given engine rpm.
A turbo charger, being driven by exhaust flow does have to wait for the exhaust to begin flowing before it can begin to produce power. But, since it is not directly coupled to the engine it top end performance is not limited by the eninge rpm.
Old Jul 23, 2002 | 04:57 AM
PaulFitzwarryne's Avatar
Apprentice Guru
Moremazda -a good responce.
Old Jul 23, 2002 | 08:53 AM
85RX7GS's Avatar
That 'essay' you wrote is summarized in my first post.
What's that supposed to mean?
Old Jul 23, 2002 | 10:55 AM
Directfreak's Avatar
I am a Jeeper Now.
Not Exactly.
    The Supercharger does NOT have it’s OWN power source, As it is obviously using the engine's pulley for it.
    A NOS system would be its OWN Power source though.
    since it is separate and apart from the engine, and does not cause any kind of parasitic drag.
    Old Jul 23, 2002 | 10:56 AM
    I am a Jeeper Now.
    WTF? Double Post.
    Old Jul 27, 2002 | 01:05 PM
    smnc's Avatar
    EliteHardcoreCannuckSquad
    One small clarification...
    Some roots type superchargers are designed for port-injected engines, and go between the throttle body and intake manifold...
    Old Jul 27, 2002 | 01:31 PM
    mar3's Avatar
    Administrator
    Either style SC also puts a severe load on the front housing eccentric bearing it was never designed to see...which is why sterling will eventually be running a tri-turbo set up with outboard IC's....
    Old Jul 27, 2002 | 02:34 PM
    Keaponlaffen's Avatar
    Originally posted by Directfreak
    WTF? Double Post.
    What's this? 1500+ posts and you still can't avoid double posting? WTF?
    Old Jul 27, 2002 | 06:25 PM
    I am a Jeeper Now.
    I usually edit my posts for grammar, spelling, links, etc, and I accidently may hit the quote button instead of the edit button.
    Once you hit submit, its on there. So the answer is yes, I fucked up.
    Old Jul 27, 2002 | 06:37 PM
    Sterling's Avatar
    Nikki-Modder Rex-Rodder
    NOT gonna happen, bitch!
    I told you; I'm gonna cross country, show up at yer door, and make you wanna pay me to do it to yer car!
    Old Jul 27, 2002 | 08:05 PM
    Apprentice Guru
    Directfreak- I thought it was possible to use edit when a post was messed up?
    Old Jul 27, 2002 | 08:09 PM
    MIKE-P-28's Avatar
    Driven a turbo FB lately?
    WTF? Double Post.
    Slacker post ***** LOL
    Old Jul 27, 2002 | 08:11 PM
    yeah, I think he's just trying to cover it up with a "double post"
    *start chant* "Post-*****, Post-*****"
    Jeff
    Old Jul 27, 2002 | 08:17 PM
    I am a Jeeper Now.
    Of course.
    You CAN EDIT and accidental post. (which I did)
    You CANNOT DELETE and accidental post though.
    I am not a post *****.
    I am however, an attention *****.
    Elevation7
    Jun 5, 2002 04:01 AM
    Sniper_X
    Feb 10, 2002 07:16 PM
    peejay
    Jan 18, 2002 07:23 AM
    vaughnc
    Oct 2, 2001 12:31 PM
    tonyge
    Aug 16, 2001 02:59 AM
