Burnt out harness switches
Old Jan 21, 2012 | 11:46 PM
dfxt14's Avatar
So I was reading FAQ's and it answered most my questions but how can i tell if a harness or switches for my dimmer and rear taillights are burnt out and how to test if any juice is going to them
Old Jan 22, 2012 | 10:53 AM
Aaron Cake's Avatar
Engine, Not Motor
FC I assume?
The harness will be obviously burned at the connector
To test the switch, look up the voltage measurements in the FSM:
http://foxed.ca/foxed/index.php?page=rx7manual
Old Jan 23, 2012 | 11:56 AM
babyhurricane1's Avatar
volt meter should do the job
Old Jan 23, 2012 | 01:03 PM
satch's Avatar
The 15 amp Illumination fuse powers the dimmer control and the tail lights. The White/Green wire is the wire powered by this fuse and this wire is found at the pigtail harness of the headlight switch. Voltage on the G/W wire is constant and also look for burn marks at the plug. The Red/Black wire in the harness receives voltage from the W/G wire when the **** is turned. If you have constant voltage on the W/G but no voltage on the R/B wire after the **** has been turned then the contact switch inside the headlight switch is poor. The Red/Green wire also receives voltage from W/G when the **** is turned and this causes the gauge lights to light up in addition to the little bulbs in the turn switch lever, hazard switch button, wiper switch and cigarette lighter, etc.
