How is the boring acheaved on 850cc injectors
Old Jan 19, 2012 | 04:34 AM
imitek's Avatar
imitek
Whats the process is it phisicaly drilled to 1300cc
And does an engineering company need to do it and how much will it cost
Thanks
Old Jan 19, 2012 | 04:54 AM
dgeesaman's Avatar
This is not a DIY job. Buy them at 1300cc. If they're used, get them cleaned/tested before installing them.
Old Jan 19, 2012 | 06:05 AM
imitek's Avatar
imitek
Thanks for the advice i always test even new injectors i had a set of rc 750 for an evo one injector was possibly the worst spray pattern ive ever seen.
I have acess to lathe and piller drills at friends engineering company so i just need to no how the process is done is it bored ? And by how much
And if i mess them up id injectors it is but i wana give it a go
Old Jan 19, 2012 | 07:16 AM
ALPSTA's Avatar
Mission Impossible
You buy a set, leave them in your garage, don't get to tune and drive your car; boring achieved
Sorry just had to say it
Old Jan 19, 2012 | 07:32 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Just use a tire plug reamer!
Old Jan 19, 2012 | 11:31 AM
imitek's Avatar
imitek
Lol think im boring in both ways my car has been sat for over a year
I saw a thread on here of a build and got me pumped up again
Yea prodigy smack my bitch up whhhhhhhhhh thats me head banging
Old Jan 19, 2012 | 11:56 AM
imitek's Avatar
imitek
U serious ?
Old Jan 19, 2012 | 02:49 PM
Gorilla RE's Avatar
U serious ?
uhh no. You will have to send them off.
-J
Old Jan 19, 2012 | 03:02 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
It a precision thing. I sent mine to RC engineering and I had them bored out from 850's to 1300's
Old Jan 19, 2012 | 03:22 PM
Mahjik's Avatar
Mr. Links
Not exactly our injectors, but you'll get the idea:
http://www.youtube.com/watch?v=Dv-xfn2xrIE
Old Jan 19, 2012 | 04:43 PM
dgeesaman's Avatar
Drills do not hold tight tolerances on size. The orifice of the injector is probably a hardened steel and wouldn't drill anyway.
Even if you could perform the work in that shop, you'd need to spend more on the special tooling than the injectors would cost.
David
Old Jan 19, 2012 | 11:41 PM
imitek's Avatar
imitek
It lookes like its flearing the injector or is it cutting anyways New injectors it is then TakE it the needle hase to be replaced as well then
Your defo right about more expencive than buying a new set of injectors
Thanks for your help guys
And the vid
Old May 3, 2013 | 10:32 AM
Tem120's Avatar
Anyone have an idea where the best place to send injectors to get bored out is ?
Old May 3, 2013 | 11:08 AM
Tem120's Avatar
Looks like RC engineering is winning the battle here.
Old May 3, 2013 | 11:13 AM
Mahjik's Avatar
Mr. Links
WitchHunter Performance - Injector Cleaning & Flow Testing Services (will so some injectors, contact them to find out)
RC Fuel Injection (has been doing RX7 injectors for years)
Old May 3, 2013 | 01:34 PM
Mitchocalypse's Avatar
Brap..
You don't bore. You buy the right size.
An 850 injector is designed to be an 850 injector. Bottom line. If you bore it, you'll more than like end up with a shitty spray pattern and terrible atomization.
Just buy the right injectors.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
