battery dies after sitting for 2 days....
Old Jan 17, 2012 | 06:19 PM
junior4022's Avatar
TX battery dies after sitting for 2 days....
i have a 1990 n/a vert and if i let it sit for 2 or more days without running it the battery drains to the point that i have to charge it all day. i was wondering if any one has had this problem and know whats going on. and do the fc's come with a stock alarm system? the reason for asking is it will sometimes engage its self and go off when ever it wants, and i was wondering if i could disarm it completely or take it out without messing something up.
Old Jan 17, 2012 | 11:39 PM
gracer7-rx7's Avatar
needs more track time
Could be the alternator as well.
Do you know how to test for current draw and for voltage?
Old Jan 17, 2012 | 11:51 PM
ra13b's Avatar
how old is your battery? if its too old it might not hold charge for very long,
Old Jan 17, 2012 | 11:57 PM
junior4022's Avatar
i personally dont know how to check the alt but i have a few people that know how.
and i dont really know how old the battery is. i have had the car for a little over a year and the battery was in it when i got it. i plan on buying a new battery if my alt checks out fine.
Old Jan 18, 2012 | 06:03 AM
dwb87's Avatar
This is my social media.
Something is, obviously, slowly draining your battery... Check for a drain.
Remove the negative battery terminal, set a multimeter to AMP current (mA), one prong to the negative car terminal, one prong to the negative battery terminal, BE SURE ALL ELECTRICAL LOADS ARE OFF, now see if the multimeter is reading very very little current (mA) or zero... If it is displaying more than it should be, remove the 60A BTN fuse from the engine fuse box (so that you can open the door of the car without the lights coming on), go into the car and start pulling fuses from the fuse panel by your feet, one at a time. If that fuse doesn't get the multimeter to display zero, then put it back in and try another fuse. You can also try pulling other things... The way I found my drain, was by unplugging my turbo timer. The multimeter then displayed zero, and that's how I knew that was the problem.
Old Jan 18, 2012 | 06:35 AM
bestcarquote's Avatar
Toyota Car Dealers Australia
Hi,
Really Nice Post, Thank You Very Much!
Old Jan 18, 2012 | 09:50 AM
junior4022's Avatar
thanks for the replies every one this will be very helpful =]
Old Jan 18, 2012 | 10:47 AM
funkjaw's Avatar
If your alarm is randomly going off.. make sure your doors are closed tight and locked, and your trunk lid is shut solid.. I mean really slam that guy down.
Old Jan 18, 2012 | 02:10 PM
junior4022's Avatar
well when i got the car the guy told me that if i lock the doors i will then have to unlock the passenger side before the driver side or else it will go off. it wasnt a problem at all, but now the passenger side door lock is broke and i cant get my key in the hole =] lol so i havent been locking it.
Old Jan 19, 2012 | 05:08 PM
TriniRotaryMan's Avatar
check the radio in the car. depends on how its connected it can run down the battery
Old Jan 19, 2012 | 09:43 PM
SM3's Avatar
SM3
make sure your you have things wired on a switched ignition.
Old Jan 23, 2012 | 02:20 PM
ericconn's Avatar
I would get the new battery either way
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Devon300zx
15
Sep 16, 2015 06:57 AM
sherff
Sep 12, 2015 12:22 PM
