TTs(OEM or BNRs) and Two-step
Old Jan 16, 2012 | 06:04 PM
oyvindjs's Avatar
I know two-step tend to be abit.... abusive... on the exhaust turbine, but how bad is it really? And i know that the axles on the OEM twins arent the thickest of the lot, so how does the twins cope with two-step?
A thought that came to mind, and i wondered if anyone had any data here, so i know if its worth the coolness of setting it up or not. On a pluss note, have everyone within a 100 feet **** their pants and duck for cover is almost worth a set of twins by itself
Old Jan 16, 2012 | 09:08 PM
arghx's Avatar
rotorhead
You would need fast-responding EGT probes pre-turbo to get the data needed. More heat is going to stress the manifold as well. You have to figure the manifolds have been heat cycled a gazillion times over the years and will be more prone to cracking.
Old Jan 17, 2012 | 02:45 AM
cptpain's Avatar
Torqueless Wonder
if you're only doing it for "coolness" then you dont need to have it at all.
Old Jan 17, 2012 | 10:27 AM
tom94RX-7's Avatar
If you're gonna use it for drag racing, it worked good for me with my twins, and only use it for a second or two at the most, that's all that is needed. The two step with my crane hi-6dsr seemed to be better because it doesn't have that cool/possibly bad machine gun sound like msds.
Old Jan 17, 2012 | 09:53 PM
oyvindjs's Avatar
cptpain, coolness is a biproduct
Im looking into it cause i want to drag the car at times too, i just want to make sure the twins can hold it and not go poo on me
thanks for answer, tom
SCinfidel
Sep 8, 2015 05:36 PM
