Engine Harness Connectors
Old Jan 16, 2012 | 04:44 PM
Gringo Grande's Avatar
1.5 Goodfella's Tall
I've spent the last couple of days searching through forum posts looking at thread after thread about Engine Harness Connectors. A common question seems to be, where can I get Connector "X" and/or what is the Part Number for Connector "X".
My understanding is that several people have sourced all of the connectors (with the possible exception of one or two). I also understand and appreciate the time it took to do so has value.
So...if anyone out there knows specific part #'s for any of the Engine Harness Connectors, please place them here. If you know them/have sources but are unwilling to share...that is fine. I'll be happy to buy connectors from you directly if you would be kind enough to PM me. I'm a DIY person and prefer to put together my personal harness on my own for the (frustration) experience.
Thanks!
Old Jan 16, 2012 | 05:35 PM
RENESISFD's Avatar
Wastegate John
I am unsure what harness connectors you are looking for but tri-point engineering has some.
http://tripointengineering.com/index...088850ee376b23
John
Old Jan 16, 2012 | 05:42 PM
Rx7aholic's Avatar
Thanks!
Hey what connectors u need I got two, us model engine harness, and I just got a 2001 long block on saturday, pm.
Khris
Old Jan 16, 2012 | 06:05 PM
dgeesaman's Avatar
John
None of those are for the ECU but still a great resource. It's all too easy to crush an OEM connector. It also bothers the **** out of me when I have a connector with a broken latch tab.
Would one of these help?
http://banzai-racing.com/store/FD_patch_harness.html
David
Old Jan 16, 2012 | 07:01 PM
Well I'm aware of the actual manufacturer of the OEM connectors is mainly Sumitomo if I recall correctly and perhaps Yazaki. I believe TYCO and AMP(?) make aftermarket connectors that work as well.
I'm looking for new, not used. Hence looking for part #'s from these manufacturers. I know, for a fact, there are at least two people on the forums who know the manufacturer and part #'s for a good 90% of the connectors. Whether they will share that knowledge as they have businesses (or at one time did) profiting from creating custom harnesses, I do not know.
I was hoping someone would share but I'll start my hunt tomorrow by contacting a number of sources with pictures and descriptions.
Old Jan 16, 2012 | 07:17 PM
BLACK MAMBA's Avatar
FD Project
dont know if this will help, i got my injector connectors from Ballanger Motorsports. also i got the crank angle sensor from C.Ludwig here on the forum.
http://www.bmotorsports.com/shop/pro...roducts_id/571
also Ballanger has the ignition coil connectors, and the female connector that plugs into the fd map sensor harness if you want to make your own gm 3 bar map harness
Old Jan 16, 2012 | 08:03 PM
Thank you sir! That is the type of info I am looking for. I understand some of these places want orders of at least 100 for the more rare connectors. I can probably work with that and am not opposed to buying a ton of connectors and supplying them to the community as long as no one is opposed to me making a buck or two on each connector since I'd be outlaying the cash in advance. =)
Old Jan 16, 2012 | 08:25 PM
prew's Avatar
I bought Aeka GSR's last set of new connectors and pins after he stopped selling FD harnesses. I ended up not building my own harness and would be willing to sell the set as a whole if you're interested.
Old Jan 16, 2012 | 08:49 PM
arghx's Avatar
rotorhead
What makes it difficult is that the original manufacturers are not going to sell you the connectors in small volumes. It's not worth their time. You have to get them through a distributor or other smaller vendor. Myself and another user on here, Sandro, got Ballengar motorsports to start stocking the connector for the stock boost control solenoids. I'm sure they bought a bunch of them and figured they could resell the part because it is used on a lot of aftermarket solenoids as well (it is an AMP/Tyco part).
Old Jan 16, 2012 | 09:23 PM
dgeesaman's Avatar
Do you have a proper connector crimper? This is very important for making a strong connection.
Old Jan 16, 2012 | 09:50 PM
I do indeed...or shall I say I have access to a few higher end pairs.
Old Jan 16, 2012 | 10:28 PM
0piston's Avatar
can you recommend one, how is this one?
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Jan 16, 2012 | 10:33 PM
Gregory Casimir's Avatar
OMG this thread is a life saver! i can finally fix my harness
Old Jan 17, 2012 | 04:39 AM
dgeesaman's Avatar
I can't vouch for that model but that's exactly the type of tool to use. I expect it to work well with automotive terminals.
Old Jan 17, 2012 | 06:35 PM
FD Project
here you go Gringo, someone just posted all the info you need.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fd-harness-connector-list-part-s-984160/
Old Jan 17, 2012 | 07:47 PM
Copying this from kclements list for relative search terms in this section. All work done by him and much respect for figuring this all out.
1993-1995 Mazda RX7 Twin Turbo to Single Turbo Harness Conversion.
Color Code
Black = Part not yet located
Red = I currently have in stock and they have been verified correct
Blue = Currently ordered and waiting for arrival to verify if it is correct
Orange = Not ordered but believed to be the correct part but not yet verified
Pink = Notes that connector is used on other sensors
__________________________________________________ ___________________________________
ECU
(1) 16 pin (2 rows of 8 pins) Yellow ECU Connector
TE/AMP PN 174514-7 Hybrid I/O Connector 16 position plug yellow
Note:
TE/AMP PN 174514-6 Hybrid I/O Connector 16 position plug (grey) is readily available and is the same plug only grey in color
(2) 26 pin (2 rows of 13pins) Hybrid (2 sizes of pins in connector) Yellow ECU
TE/AMP PN 174516-7 Hybrid I/O Conn Plug HSG 26P (yellow)
(3) 10pin (4 top with key in center and 6 on bottom) Blue ECU
TE/AMP PN 176114-5 070 MLC II Plug ASSY 10P (Blue)
NOTE:
TE/AMP PN 176114-6 070 MLC II Plug ASSY 10P (Grey) is readily available and is the same plug only grey in color.
(4) 14pin (6 top with key in center and 8 on bottom) White ECU
TE/AMP PN 173852-1 070 Multilock Plug 14p (white)
Transmission Harness
(5) Grey 2 pin with Orange insert
Sumitomo PN M(6195-0006) DL Sealed Series 2way plug Male
Notes:
REF. Terminal part # O-07
REF. Wire Seal part # O-08
REF. Dummy Plug # O-09
Color Dark Grey
NOTE: This connector is common to:
Air Pump Mate
EGR Mate
(6) Black 4 pin with yellow insert
TE/AMP Part #TYC 174259-2 (Connector)
TE/AMP Part # TYC 174260-7 (Insert)
TE/AMP Part# TYC 172746-1 (Black wire sealer plug 4 needed)
(7) Black 2 pin
TE/AMP Part # TYC 174354-2 (Connector)
TE/AMP Part # TYC 174355-7 (Insert)
TE/AMP Part# TYC 172746-1 (Black wire sealer plug 2 needed)
Note: Connector is also common to:
Boost solenoid Mate
Air Temp Mate
EVAP Purge solenoid Mate
Turbo Control solenoid Mate
(8) Grey 2 pin with orange insert
Sumitomo PN M(6195-0003) DL Sealed Series 2way plug Female
Notes:
Color Dark Grey
Main Harness
(9) IAT Black 2 pin
TE/AMP Part # TYC 174352-2 (Connector)
TE/AMP Part # TYC 174353-7 (Insert)
Boost solenoid
Reverse Transmission Switch (tranny side)
EVAP Purge solenoid
(10) O2 Black 1 pin
TE/AMP PN 174877-2 Econoseal J Series [Mark II (+)] 1 position
Note:
Use part number 174879-2 (Male) for Sensor side
(11) IAC White 2 pin No insert
(12) TPS Grey Flat 4 pin orange insert
Sumitomo PN F(6195-0030) DL Series 4 Flat 4 way Female
Notes:
Color Dark Grey
(13) INJ Secondary Rear Grey 2 pin Orange Insert
Sumitomo PN F(6195-0043) DL Sealed Series
Color Dark Grey
(14) INJ Primary Front Grey 2 pin Orange Insert
Color Dark Grey
(15) INJ Primary Rear Grey 2 pin Orange Insert
Color Dark Grey
(16) INJ Secondary Front Grey 2 pin Orange Insert
Color Dark Grey
(17) Tstat Housing Black 2 pin
(18) Tstat Housing Green 2 pin 3 way key top L&R and bottom no insert
TE/AMP PN 178449-4 Econoseal J Series [Mark II (+)] Green
Note:
TE/AMP PN 178392-6 Econoseal J Series [Mark II (+)] Gray is readily available and is the same plug only grey in color
(19) Fuel Temp same as #18 Above
Note:
(20) H20 Thermofan 1 pin round black no insert
(21) Crank angle grey 2 pin orange insert L&R key at bottom
Notes:
Color Dark Grey
Air Pump
Vehicle Speed Sensor
EGR
(22) Crank angle white 2 pin orange insert L&R key at bottom
Notes:
Color Dark Grey (couldn’t locate white)
Air Pump
EGR
(23) OMP 10pin (2 rows of 5 pins) Black with yellow insert
TE/AMP PN 174655-2 Econoseal J Series [Mark II (+)] 10pin (2 rows of 5 pins)
Also need :
174656-7 Double lock plate
171630-1 Contact (receptacle) 10 pieces
(24) MAP Sensor (Stock)
AMP/TE Connect PN TYC 174357-2 Econoseal J series [Mark II(+) Black 3 pin
Also needed:
Note:
PN TYC 174359-2 is “Mate” end of this plug
Also Needed
TYC 174360-7 Insert
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
befarrer
Aug 14, 2015 04:18 PM
