My ICSCC ST FC3S Race car build
Old Jan 14, 2012 | 04:56 PM
CJarrett's Avatar
FC Racer
It has been in the works for quite awhile now, and I've posted a lot of questions but finally have some time while I watch the Saint's/49'ers game to post up a build thread. I've been posting some upates on Speedhunters, but work has progressed slowly through 2011 so I didn't update very much.
I am building the car for both Time Attack/Solo Sprint, as well as the ICSCC Sport Touring rules, which is based around a 1:10 power to weight ratio.
The chassis I started with was a pretty tired 1988 GX base, had no sunroof which gave me more headroom, and less weight up top.
Old Jan 14, 2012 | 05:00 PM
CJarrett's Avatar
FC Racer
Car was stored on top of a storage container for a year before I found it. Picked it up for $200 and brought it home.
Had some sweet seat covers
And stickers
Also picked up a donor car, for suspension, 5 lug, S5 engine, and some other bits.
I had just had laser eye surgery when I needed to tear apart the S5, and pull the S4 engine, so I asked the local Rotary boys to come and help, and they had the car apart in an hour or so and helped me pull the other engine in exchange for a few free parts.
Old Jan 14, 2012 | 05:06 PM
CJarrett's Avatar
FC Racer
Spent a bunch of time tearing into the car and stripping it down to the bare shell.
Once it was stripped down it was time to repair the bit of rust it had and get the roll cage in.
Old Jan 14, 2012 | 05:09 PM
CJarrett's Avatar
FC Racer
Got the interior stripped down, used dry ice to help freeze the stick sound deadening out and a heat gun to scrape the rest out.
Once that was done, was time to stitch weld the chassis.
Had to strip out all the seam sealer which is a bitch of a job, but with a chassis over 20 years old, worth it IMO.
Old Jan 14, 2012 | 05:15 PM
CJarrett's Avatar
FC Racer
Went out to my friend Colin's shop and we built ourselves a hydraulic tubing bender and started on the cage. The bender was hooked up to his forklift, so you could use the forklift controls to control the bender, pretty slick actually.
Attached Thumbnails My ICSCC ST FC3S Race car build-img_0296.jpg   My ICSCC ST FC3S Race car build-img_0308.jpg   My ICSCC ST FC3S Race car build-img_0317.jpg   My ICSCC ST FC3S Race car build-img_0325.jpg   My ICSCC ST FC3S Race car build-img_0362.jpg
Old Jan 14, 2012 | 05:19 PM
CJarrett's Avatar
FC Racer
Cage turned out pretty well. Used 1.75" 0.095" wall DOM, but looking back I may have used 1.625" next time.
Being 6'4" I need all the headroom I could get, so the cage was tucked up as far as possible
Also made sure the A-pillar bars were in line with my line of sight with the a-pillars, giving me the best outward visibility.
Nascar style bars on the drivers side
X-bars on the passenger side
Old Jan 14, 2012 | 05:23 PM
CJarrett's Avatar
FC Racer
Gutted and lightened the doors, made my own brackets for the stock inner door handles.
Bought some bolt-through dimple dies and made myself some gussets for the cage since the rules for my class allow any points of attachment for the cages.
Gutted my hatch too. Needs lexan next.
Old Jan 14, 2012 | 05:27 PM
CJarrett's Avatar
FC Racer
Build myself some basic rotisserie stands so I could rotate the car and access the bottom easily to clean it up and stitch weld it.
Then Dave (docholiday) helped me clean up the bottom of the car and remove 22 years of gunk.
Also built a custom strut brace, but will re-make it out of aluminum.
Old Jan 14, 2012 | 05:29 PM
CJarrett's Avatar
FC Racer
Flyin Miata helped me re-build my steering rack and de-power it. This is the S5 rack so its the perfect ratio for de-powering.
Realized I was still too tall with my Sabelt Taurus seat, so docholiday built me a drop box and we welded it in.
Not bad for a tall dude...
Old Jan 14, 2012 | 05:33 PM
CJarrett's Avatar
FC Racer
Got my balance bar and dual MC's for the brake adjustment system.
Dave/docholiday helping me get the pedal box modified so I can run the dual MC setup.
Made a new mounting hole from guidance from a few of you guys, helping the pedal ratio for better brake feel with the manual brakes.
Old Jan 14, 2012 | 05:40 PM
CJarrett's Avatar
FC Racer
Our cat Juicy in my test seat...
Picked up a set of 17x8 BBS RS's in decent shape. Bought some new lips for them so time to rebuilt the wheels. Had to bake them first (wife loved that part)
Get them apart...
Re-painted the centers and get them back together.
Lookin good!
Old Jan 14, 2012 | 05:45 PM
CJarrett's Avatar
FC Racer
Awesome looking Pettit Trak-Pro Race spec coilovers. Can't wait to get these mounted.
Got my daughter to paint my side mirrors.
Yep, they are pink.
AWR 2 piece rotors
AWR brake ducts
Got the bottom sealed up
Momo dished wheel.
Old Jan 14, 2012 | 05:47 PM
CJarrett's Avatar
FC Racer
Trimmed the dash to fit with the cage and dyed it black.
Painted a few of the suspension members
JDM TII trans and Mazdatrix short shifter with an extension I made.
Old Jan 14, 2012 | 05:48 PM
Ball joint's Avatar
Turbo Lover
Looks great! Takes a patient man to do all that stitch welding.
Is that cat a Savannah?
Old Jan 14, 2012 | 05:53 PM
CJarrett's Avatar
FC Racer
Dave and I machined some upper diff mounts.
And we got the car fully sealed up with epoxy primer.
The cat is a bengal, and she is rad. She attacks our 95lb doberman all the time.
Old Jan 14, 2012 | 06:03 PM
CJarrett's Avatar
FC Racer
Also did a few concept renders to see how I thought it would look when I'm done. Have some new fender designs, and a different front bumper/headlight treatment now. If I get some time I'll update them.
Also decided on going black. Every vehicle I've owned/own is black... even the Fiat 500 I will be restoring will be black.
Old Jan 14, 2012 | 06:10 PM
IAN's Avatar
IAN
Rotary Reborn!
Awesome. Keep us posted please on the build. Subscribed...
Old Jan 14, 2012 | 08:48 PM
HotRodMex's Avatar
I was following the build on Speedhunters. Glad to see it up over here.
Old Jan 15, 2012 | 05:46 AM
Brent Dalton's Avatar
Sua Sponte
Very nice, well thought out track car. Can't wait to see some more updates!
Old Jan 15, 2012 | 01:30 PM
BigAl...'s Avatar
Love your Fabricator!
Just stumbled across your build, looks like the beginnings of a great racecar except for the pink mirrors . All kidding aside you're off to a great start!
Old Jan 15, 2012 | 06:12 PM
Infidel's Avatar
yes! excellent choice of wheels, i'm actually looking for some donors myself. what were the before and after widths, and offsets if you don't mind me asking, and what size lip did you add.
I've also been following on speedhunters. Looks like it's going to be amazing.
Old Jan 15, 2012 | 11:33 PM
CJarrett's Avatar
FC Racer
Thanks BigAl, been watching yours closely too, can't wait to see it all finished.
Wheels were 8" wide with a 1" lip stock, put on a 3.5" lip and are now 11.5" wide. However, ST only allows 10" wheels in competition, so these may become my Time Attack wheels and get some RPF01's for ST.
Old Jan 16, 2012 | 12:22 AM
TyFc3s's Avatar
JPR imports helper monkey
Awesome work so far, ive been following this build on speedhunters and cant believe that i almost forgot about it, lol, i guess its been alittle while.. beautiful car/build, and i cant wait to see more done
im subscribing
Old Jan 16, 2012 | 09:31 AM
Richard.C's Avatar
I love the renderings, the car is going to look fantastic.
Good luck with the build.
Richard
Old Jan 16, 2012 | 09:48 AM
bigdv519's Avatar
IFO Forced Induction Slo
Subscribed!! Great build. I think I'm inspired to build a rotisserie myself for my other project.
