Aeromotive 340 Stealth Fuel Pump
Old Jan 12, 2012 | 10:02 AM
swif's Avatar
Almost back together
So I did a search on this pump to see what people have found when installed in our cars. I was unable to find information with numbers just for this pump. Seems everyone brings in other pumps.
I also researched this pump form other forums and on other cars and seems to do well.
I have this pump, but do not have my car running yet. I would like to have anyone running this pump please give feead back good or bad. List what numbers you see as well as injector size and HP numbers.
Old Jan 12, 2012 | 10:31 AM
tom94RX-7's Avatar
It works great, I'm using it, over 500 hp, 24 psi boost, 44 base fuel pressure, 850's and 1680s, stock fuel lines except for the 6an lines to and from the aeromotive fpr. Logging fuel pressure and afr. Others have used it on here.
Old Jan 12, 2012 | 11:03 AM
demon721's Avatar
is that a wankel.
im currently running this aswell but its in my fc and my setup its a lil different running 15lbs 550 prim and secondary 820 secon 44 base fuel pressure aswell and it seems to be working so far. car still needs more tuning but i am happy with it plus if i go bigger on injectors i will have no issues later
Old Jan 12, 2012 | 11:36 AM
Rx7aholic's Avatar
Im running 550, ID2000, To4s @15 psi boost and with base fuel pressure at 40, same type of pump, injector duty is 59%.
Old Jan 12, 2012 | 12:37 PM
BurntOrangeT2's Avatar
No phonebook but OG calls
That's pretty impressive with that fuel pressure.
This pump sounds more and more attractive, especially given the price point on these.
Plus its made in the US, in KC nonetheless.
Old Jan 12, 2012 | 12:53 PM
Rxsteven's Avatar
Newbie
i personally like the Aeromotive A1000 fuel pump, and thats what im running to 500 hp also. Downside to that fuel pump is overheating, so you MUST run a regulator (aeromotive part also) if you are going to drive the car on the street for moderate distances. Sorry for getting off topic, but from what i understand the stealth is superior to the A1000 for both street and strip and i have seen nice custom setups for the a1000 done by Speedtek out in deer park.
Old Jan 12, 2012 | 04:21 PM
Jason's Avatar
The one
That pump is loud as hell. Sounds like a chain saw
Old Jan 12, 2012 | 04:26 PM
BLACK MAMBA's Avatar
FD Project
im running dual 340 pumps with 1000/2000 id, so far no problem, but running only 15 psi at the moment
Old Jan 12, 2012 | 08:11 PM
swif's Avatar
Lets try and stay on the one pump please.
Thanks for the input so far.
FC3S1991, why are you running two of these pumps and only boosting 15psi? What kind of power are you looking for with those injectors?
to give you guys an idea I have 850/ 2000 ids, apex gt3574 turbo, looking to get 400 wrhp with out port my engine. When time comes to port engine on a rebuilt I will move to a larger turbo (maybe 500R) and look to get 500 wrhp with the current fuel set up and add a meth kit.
Old Jan 14, 2012 | 12:35 AM
misterstyx69's Avatar
Retired Moderator, RIP
there are 3 pumps like that.l am interested in getting one.
Is the pump that you Guys are using the "offset inline with outlet" style?.(FC application)
Old Jan 14, 2012 | 09:14 AM
tom94RX-7's Avatar
http://aeromotiveinc.com/products-pa...-offset-inlet/
Old Jan 14, 2012 | 09:53 AM
PvillKnight7's Avatar
Lol. If only that was in the description.
Old Jan 14, 2012 | 06:12 PM
FD Project
when i started to build the motor and single turbo conversion i was planning on a setup for around 550hp, and just for the safety of having enough fuel thats why i went with dual pumps.
right now the car has only a rough tune thats why im only running 15psi, i might switch the pump setup and leave 1 of the pumps running 1 hook to a boost pressure switch later down the road.
Old Jan 14, 2012 | 07:28 PM
RotaryEvolution's Avatar
Sharp Claws
personally i'd try to stick to 1 pump if and when possible. the last thing you want is your secondary pump to fail and not know it until you do a pass, bye bye motor.
the 340 is plenty enough for about 600whp, if it can handle a kenne belle boost a pump then more like 800-900. downside is for anything more than 500whp you need a larger fuel feed line under the vehicle.
Old Jan 14, 2012 | 08:02 PM
R-X-R's Avatar
so "offset inline with outlet" is the one u want for FC?.,.,
Old Jan 14, 2012 | 08:59 PM
tom94RX-7's Avatar
The one I linked to is the one you want. Someone on here years ago ran 700 hp with the stock hard lines, and I have not had a problem with using just them.
EVeryone should be logging fuel pressure which is easy to do with a autometer electronic fuel pressure gauge and datalogit.
Old Jan 14, 2012 | 09:42 PM
R-X-R's Avatar
so fd and fc can take the same pump [11141] bascially
Old Jan 14, 2012 | 09:45 PM
tom94RX-7's Avatar
This pump is not a direct replacement, it doesn't install the same as the Denso stock pumps, some little easy modification is required. I'll upload a pic of mine
Old Jan 14, 2012 | 09:51 PM
tom94RX-7's Avatar
See picture attached. I was also doing a rewire with 10 gauge gasoline resistant wire to the pump.
Attached Thumbnails Aeromotive 340 Stealth Fuel Pump-6312084925_48ae7ff717_z.jpg
Old Jan 15, 2012 | 02:30 PM
swif's Avatar
Thanks for the picture.
Old Jan 15, 2012 | 02:47 PM
tom94RX-7's Avatar
When I was installing it I remember thinking it might have installed easier if I had # 11142, the hose might line up better, either one will work. http://aeromotiveinc.com/products-pa...-inlet-inline/
Old Jan 15, 2012 | 05:19 PM
R-X-R's Avatar
thanks for the pic. now i know what to order. wut is the point in rewire?
Old Jan 15, 2012 | 05:25 PM
tom94RX-7's Avatar
Do a quick search for lots of info. The stock wiring isn't enough to get the full potential from any pumps. ReWire with a relay gets the pump more voltage so it can flow more than it would with stock wiring.
Old Jan 15, 2012 | 05:34 PM
R-X-R's Avatar
for a 350WHP goal is it really necessary?
Old Jan 15, 2012 | 06:15 PM
tom94RX-7's Avatar
The rewire may not be necessary for you, there is easier ways to do it which will help some, I didn't send the new wires down to the pump until about 500 hp. Search
