Single Turbo Cold Air Intake Ideas
Old Jan 11, 2012 | 12:03 PM
renkenkyo's Avatar
Not Track Ready
Hi Everyone,
I'm trying to figure a good way to plumb/duck cold air to my single turbo setup . I'm going to be running the RE-A N1-Facer (05) front bumper (currently using the FEED), CompTurbo 6065, DOC race manifold, and Defined Autoworks V-mount kit.
I'm wondering what the best place to draw in fresh air for the turbo is . Most of the setups I've seen pictures of just pipe it some where close to the intercooler or place a filter directly on the turbo. Is there a cold air setup people are using for a single? My car currently has the head light air intake slot (FEED) but I plan to take out the pop up lights. Any suggestions would be appreciated.
Old Jan 11, 2012 | 12:17 PM
Gringo Grande's Avatar
1.5 Goodfella's Tall
Look in Ruler Mark's Build Thread. He had a fairly robust CAI/ducting he fashioned for his car.
Old Jan 11, 2012 | 12:36 PM
renkenkyo's Avatar
Not Track Ready
Saw the thread. Really neat idea, only problem for me is it takes the entire right head light position for the air intake. I still need some sort of light there.
Old Jan 11, 2012 | 08:40 PM
ninesixtwo's Avatar
No Glory
I know you already have your intercooler purchased, but the solution for me was to run a water to air exchanger. I'll be mounting it up sometime february. Because the intercooler itself doesn't require airflow, I was free to mount a huge airbox at the front of the engine bay and allows you to run the stock intercooler duct into the airbox.
Old Jan 11, 2012 | 08:56 PM
Double_J's Avatar
Thewird has a nice setup for fresh air intake. Since you have a vmount you could do something similar.
Old Jan 11, 2012 | 09:20 PM
oyvindjs's Avatar
Function >>> form.
non-collapsable pipe/hose hooked onto turbo, leads down to corner intake in bumper, under light. Put filter there.
Easy, cheap and all the fresh air you need. Looks industrial and efficient too
Old Jan 12, 2012 | 10:26 AM
tom94RX-7's Avatar
I made a nice one that goes down into the bumper but the headlight motor gets removed and headlight mounted in fixed upright position, I don't mind that, and I mount just the headlight cover in the down position when I go drag racing, just made a bunch of brackets for mounting. If search you can find my pics and info about it.
Old Jan 12, 2012 | 10:43 AM
theorie's Avatar
AponOUT!?
I'm making a custom back plate for the M2 airbox, for my single setup that is currently in the works. The M2 box draws air from the front bumper opening, with a scoop that goes between the side of the radiator & the body.
Old Jan 13, 2012 | 04:00 AM
renkenkyo's Avatar
Not Track Ready
That's not a half bad idea if I change my setup in the future. Do you gain or lose any weight with the water exchanger? Are your water temps any higher?
Originally Posted by oyvindjs
Function >>> form.
non-collapsable pipe/hose hooked onto turbo, leads down to corner intake in bumper, under light. Put filter there. Easy, cheap and all the fresh air you need. Looks industrial and efficient too
That's the v-mount kit I'm using (not my car FYI). Are you talking about the spacing on the passenger side?
Would this work with fixed headlights like the RE-A style?
Would this work with a front bumper like the FEED or RE-A style? Any pictures?
Thanks for all the info
Old Jan 13, 2012 | 04:48 PM
renkenkyo's Avatar
Not Track Ready
I looked up the setup thewird had. It looks pretty good but I'll need a slimer version and also remove part of the ducting on the v-mount in order to access the air.
Old Jan 15, 2012 | 09:30 PM
FD3S2005's Avatar
SideWayZ The Only Way
iv seen thewird's setup in a thread before and it looks very good and functional, i would like to do something like that some day
sherff
Feb 24, 2019 12:09 PM
Wolf_
Aug 11, 2015 04:23 PM
