Lsd?
Old Jul 21, 2002 | 01:04 PM
zaridar's Avatar
35r 13b first gen
Lsd?
I have a 1985 gs with a 12 a. Does anyone know if my car has a Limited Slip Differential or not?
How can I tell?
Thanks
Old Jul 21, 2002 | 01:12 PM
Jeff20B's Avatar
Lapping = Fapping
Why not put both questions into a single post? Anyway, jack up the rearend and turn one tire. If the other turns the same way, it's LSD. If not, it's a regular diff.
82streetracer's Avatar
8/1 Building/Drive Ratio
no, gs didnt have a LSD, if your car has rear disk brakes, then it probably has one, but gs dont.
Old Jul 21, 2002 | 02:32 PM
inittab's Avatar
I read your email
Drive your left rear tire onto a patch of grass with your right rear tire on pavement. Then rev it up high and dump the clutch. If your right rear tire leaves a decent patch of rubber behind then you've got a LSD rear.
Old Jul 21, 2002 | 03:41 PM
Barwick's Avatar
SCCA Rookie
no.. listen to Jeff20B.. jack up the rear end (the WHOLE rear end) and turn one tire. If the other turns the same way then it has LSD.
Old Jul 21, 2002 | 04:00 PM
Pedestrian X's Avatar
SpAz!
oh. but thats just not as much fun :[
Old Jul 21, 2002 | 04:09 PM
inittab's Avatar
I read your email
yeah okay but my method is much more fun. :P Either method will test positive on a new LSD but keep in mind that the clutches loosen up over time and both tests can fail for you. BTW, my rear has a bright yellow sticker on it that says "Limited Slip Differential", that's probably the easiest method.
Old Jul 22, 2002 | 12:31 AM
zaridar's Avatar
35r 13b first gen
THanks!!
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
