Where to get an alignment?
iv dont all my bushings and need to get the car align. I have the stock height but firestone next to my house was going to do it but as the car was going to be put on, they had to stop or else it would of hit the front bumper.. Is there a shop that has a lower alignment machine in south florida???
thanks joe, just got to finish up putting in the new tie rods now and i should be ready. Just curious if you dont mind me asking, around how much was it?
Trending Topics
well now i have a new problem, and not sure if my power steering or rack is going bad. just as i finished the tie rods
here is the thread about it, https://www.rx7club.com/3rd-generation-specific-1993-2002-16/power-steering-issues-983359/
Edgar has done at least 5 alignments on my cars in the last two years....
2 on my C32 to determine why car was pulling to the right and also install crash bolts to adjust caster
1 on my FD after a penguin installed my coilovers
1 on my E55 because of the big rims and i needed camber dialed back in
1 on my SC300 because the same penguin replaced the control arms. He was assisted by an even bigger penguin that knocked over a MAC TOOLS truck to pry off control arm from body.
nice, my plan is to go tomorrow after school. any type of settings i should tell him to put it at or just stock? was thinking to do atleast -1.2 camber all around going by howard coleman notes.
what are you running on your fd?
"The Penguin"
so everything was going well. got the alignment today. just as i was leaving, i noticed when i hold the wheel straight, it pulls to the left. I made a u-turn and went back he checked and noticed my bushings on my Improved racing Toe links were worn and the rear tire had some play.. Edgar said its likely the toe links, but could this cause the pulling to the left while the wheel is straight and driving at city speeds? or could it be a wheel bearing?
good news is that improved racing (Michael) will be sending me 4 new replacement bushings(end links) for the toe links. Their customer service is pretty good, and they get back to you right away. Was all settled in 1 day. Says that they have found that the nylon-lined ends wear out a little faster so he will be sending me ones with teflon liners instead!
Spirit Rx-7
Mar 14, 2016 12:36 PM
imitek
13
Oct 28, 2015 10:57 AM
erevos
Sep 15, 2015 09:19 AM
