rx3 rear brakes.
Old Dec 29, 2011 | 11:39 PM
treceBturbo's Avatar
rx3 rear brakes.
i am in the middle of doing that rear disc conversion using the GSL parts?, and i read on the respeed forum, that to get it done properly its saying to cut some plate off? what plate? can anyone help me with pictures, or anything, and is it even worth the conversion?
Does it stop better? or does it just look better than those nasty drum brakes?
thanks
-eddie
any help will be appreciated
Old Dec 30, 2011 | 08:35 AM
Siraniko's Avatar
RX for fun
imho, u wont be able to tell the difference unless you upgrade the front. And definitely, much better braking if u change the booster also to 81-85
Old Dec 30, 2011 | 08:38 AM
Siraniko's Avatar
RX for fun
The bCking plate needs to come off. either cut it or pull out the axle completely to remove the plate. You will need the gsl.end ebrake.cable and a trip to homedepot
Old Dec 30, 2011 | 07:08 PM
then how would the alxe be held then if i cut off the backing plate?
Old Dec 30, 2011 | 07:15 PM
thanks wacky =)
Old Dec 31, 2011 | 01:41 AM
Siraniko's Avatar
RX for fun
remove the backing plate not the axle retainer plate, reinstall the axle and secure it to the axle flange (there are 3 bolts) with a new high grade bolts and nuts (i dont have the thread pitch and length handy at this time) but I believe RE-Speed comes with it. old pix but somewhat still handy
RX-3
RX-2
Old Dec 31, 2011 | 06:15 PM
oooo...i feel stupid now =) i understand now. thank u =) happy new year be safe.
-eddie
thanks again
Old Jan 4, 2012 | 06:22 PM
well about ur rx-3, did u convert to the FB rear suspension? and for the front FB strut how did u extend it? just got a piece of tube the same size and welded it on?
Old Jan 4, 2012 | 06:26 PM
Gsl se
and about the rear rotors...u can just get the ones from a GSL SE cuz they are vented, just have to drill them out a bit =) im in the process, my grandpa is a machinist so hes helping me out
Old Jan 4, 2012 | 06:57 PM
cfamilyfix's Avatar
I think the RX3 guys who run the FB front suspension either live with the drop or space up the body from the strut mount (shims etc...)
Old Jan 4, 2012 | 09:07 PM
Siraniko's Avatar
RX for fun
well about ur rx-3, dgzid u conv,ert to the FB rear suspension? and for the front FB strut how did u extend it? just got a piece of tube the same size and welded it on?
Yes and yes. One has a cut tube and extended using a tube/pipe. The other has abextended tube using 2 sets of fb strut tubes
Old Jan 4, 2012 | 09:10 PM
Siraniko's Avatar
RX for fun
I used gsl parts since i have a good supply of gsl parts
Old Jan 4, 2012 | 09:22 PM
cfamilyfix's Avatar
Hey Wacky...
Do you use the RE Speed strut tube spacer then...you know like the spacer that goes under the strut insert? Does it help with ride height issues??? my GLC is just about the same as a RX3 in the front...so you know I'm interested. Thanks.
Old Jan 4, 2012 | 09:30 PM
Siraniko's Avatar
RX for fun
yeah respeed aluminum spacer plus a 1" triangular shape alumninum spacer beteeen respeed camber kit and strut tower
Old Jan 4, 2012 | 09:37 PM
cfamilyfix's Avatar
Ahhhh...perfect! You move the spring perch up too?? I'm gonna search for a thread instead of highjackin' this thread...thanks again Wacky!
Old Jan 5, 2012 | 08:26 AM
Siraniko's Avatar
RX for fun
yeah, move the spring perch
Old Jan 8, 2012 | 10:38 PM
nevermind about the GSL-SE rear rotors hub circle is too large. so its a bit sketchy. and wacky did u do all the welding ur self? =)
Old Jan 10, 2012 | 08:27 AM
Siraniko's Avatar
RX for fun
nope as I didnt own a welder at that time, though I was certified by City of LA back in the days but was unable to find a job in the 80s so I switched career lol. I just purchased a low budget mig from HP but hasnt found time to do anything.
Islandnow did the first set of tube and RMS took care of the second one. Just take your time with chop chop and be sure to grind/remove the paint where it needs to be welded, make life easier for whoever gonna weld it.
Old Jan 10, 2012 | 11:38 PM
is it me or do u have more wheel clearence with the FB struts? and i didnt realize how much space an rx3 has lol
Old Jan 10, 2012 | 11:48 PM
cfamilyfix's Avatar
The fb perch is much smaller than an RX3 perch, so it looks more spacious.
Old Jan 11, 2012 | 12:18 AM
Siraniko's Avatar
RX for fun
Thats on my black RX-3. It has fb struts with 626 rwd koni which has same diameter as fb cartridge but same lenght as a RX-3.
Old Jan 16, 2012 | 12:23 AM
by any chance did u remove the residual valve in the master cylinder? or would that cause a bad case of rear lock up? i went to sevenstock, were u there?
http://www.bonanza.com/listings/Func...-74-75/8817814
and these seem like they would fit?
Old Jan 16, 2012 | 07:20 PM
Siraniko's Avatar
RX for fun
I tried them with and without the residual valve (FB and RWD GLC/626) but I didnt notice any difference as my rear never locked up. But since these M/C were used from junkyard (yeah, pocket items so they were free lol), I've changed the M/C on all of my RX-3 to GSL and GSL-SE as I found a good deal on new ones.
Yeah I was at 7stock, parked between a rotary 510 and rotary mango and islandsnow yellow RX-3. No experience with function form as I dont own a RX-2; besides, I cant see myself spending that much.
Old Jan 16, 2012 | 10:12 PM
nice. i took a picture of it. one of the cleanest RX-3s there, woulda said hi but didnt know. next time lol, well i wish rx7 calipers werent so expensive. but i kno its the actuator for the handbrake =)
Old Jan 16, 2012 | 10:14 PM
i kind of prefer the early front end oppose to the later one. i have the same body style as urs.
