Sponsored by: CARiD
How much power can a lighter supply?
Old Jul 20, 2002 | 02:11 PM
Tom93R1's Avatar
gross polluter
I have a really small (200W) power inverter and a laptop I would like to run through my cigarette lighter. The laptop has a very low capacity battery and I need something to run my datalogit. My laptop power supply has a max output of 40W, figure in some losses because the inverter and the power supply are not perfect and you get maybe 60W max. Is the lighter going to be able to supply this?
Old Jul 21, 2002 | 09:42 AM
peejay's Avatar
Old [Sch|F]ool
Most lighters can supply up to 10A which is about 140W with the engine running.
Old Jul 21, 2002 | 11:53 AM
Tom93R1's Avatar
gross polluter
Cool, I guess I don't have to worry about electrical fires when running my laptop.
Old Jul 21, 2002 | 04:32 PM
peejay's Avatar
Old [Sch|F]ool
You wouldn't cause an electric fire, you'd just blow a fuse
Old Jul 21, 2002 | 04:59 PM
Tom93R1's Avatar
gross polluter
If I blew a fuse and jumpered it with a wire then I could cause a fire
Don't worry, the only fuse I jumper is the wiper fuse in my REPU, the 7 is safe from that.
Old Jul 22, 2002 | 12:53 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
most laptops run on 12v and you can get car adapters for them, check out your local radio shack.
Old Jul 22, 2002 | 02:46 PM
Tom93R1's Avatar
gross polluter
Sony had to be difficult though, mine runs on 16V. I haven't even been able to find a Sony-made adaptor for mine. I will look around again, it has been awhile since I last checked.
Old Jul 22, 2002 | 11:56 PM
artowar2's Avatar
C'mon, admit it. You're going to try one of those use-my-leafblower-as-a-supercharger projects, aren't you?
The fuse on my FD's cig lighter blew when I tried to use a portable electric airpump on it. Had to use my truck's lighter socket instead...
rx7shirley
Sep 2, 2015 02:11 PM
