does the timing change if you add msd 6al
Old Jul 20, 2002 | 12:39 PM
minocqa's Avatar
hi
i bought a msd 6al
do i need to reset the timing when i install it.
if so what do i set it too ...85 gs 12a
thanks
Old Jul 20, 2002 | 12:47 PM
diabolical1's Avatar
no, the timing doesn't change. i think all you're doing is changing the way the coil fires when you add the 6AL.
Old Jul 20, 2002 | 08:55 PM
If you get your msd to work, let me know, i installed mine, and my car hasn't run the same since.
Old Jul 21, 2002 | 01:35 AM
jerij's Avatar
Blitz,
I used Mazspeed's write up to set mine up. Cranked right up, no problems.
However.... I have had about ~1-2mpg DROP in my mileage. I'm not rompin' either.
Any thoughts?
jeryj
Old Jul 21, 2002 | 06:17 AM
Thats the write up i used on mine as well... still have issues though.
Old Jul 21, 2002 | 09:15 PM
i hope i'm not insulting you, but if i am then you have my deepest apologies ...
did you take out the "test" plug out of the rev limiter and put in one of the high RPM ones?
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
MoTeC
Sep 10, 2015 07:58 PM
