Pulling engine with automatic transmission
Old Dec 13, 2011 | 02:16 PM
fathertime's Avatar
I need to pull the engine on a 1991 rx7 convertable to do a rebuild. Is it better to pull both engine & automatic tranny or can I just pull the engine only and leave the tranny in the car? Any problems I might run into? Thanks for any info you can give me.
Old Dec 13, 2011 | 04:08 PM
stevensimon's Avatar
pull them together. its easier coming out and going back in
Old Dec 13, 2011 | 04:37 PM
fcdin's Avatar
If you pull both at the same time. Be sure to drain out the trans fuild. Otherwise itll get all over the floor when you pull your engine. This happened to me. -_-
Old Dec 13, 2011 | 05:27 PM
youngfc's Avatar
take them out i had to do this a few times, and keepin the tq converter from comin out, along with lining everything back up sucked. ps its also easier to get all the mounts where they need to go. good luck.
Th0m4s
Feb 26, 2019 02:04 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
maikelc
Aug 24, 2015 11:04 AM
