West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Leaking Oil..Options?
Old Dec 12, 2011 | 10:41 AM
ArmAnirx7's Avatar
I just started seeing small oil marks on my driveway. What is the best way to find where the leak is from. Any suggestions?
Old Dec 12, 2011 | 12:06 PM
ArmAnirx7's Avatar
anyone?
Old Dec 12, 2011 | 12:59 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
Steps
1- Get under your car
2- Wipe down all oil and grease with gereaser or solvent.
3- inspect main oil holding components, oil pan,transmission oil pan ,front and rear engine meet points, differential.
4- If you still cant find the leaks this is another alternative and works. Get baby powder and put all under your car. It will be easier to pin point where its coming from.
NOTE- 99% its the oil pan, oil cooler lines, tranny seals, differential axles.
Old Dec 12, 2011 | 01:26 PM
reo's Avatar
reo
follow the oil uphill, it like other substances flown down hill. try letting car run in a fresh spot. then look
Old Dec 12, 2011 | 03:06 PM
ArmAnirx7's Avatar
Thanks guys! I will try this out as soon as this rain stops
Old Dec 12, 2011 | 08:20 PM
RicerJ's Avatar
Rotary its a way of life
my guess is its the oil cooler lines or the oil pan
Old Dec 12, 2011 | 08:26 PM
ArmAnirx7's Avatar
The leaks on my drive way are like a quarter size drops..might be from the oil cooler line.. I'm gonna go under the car soon and I will keep you guys updated. Thanks
Old Dec 12, 2011 | 08:42 PM
lftalbert's Avatar
OR leaking oil, option
so glad you asked. I think I have same problem. Reading this gave mr ideas of how to start finding leak. Thanks goys Hey I'm in Oregon too. Can we be friends?
Old Dec 12, 2011 | 08:48 PM
ArmAnirx7's Avatar
of course.. we are all friends here... let me know where you find your leak.. it might be the same issue as mine
Old Dec 12, 2011 | 09:30 PM
RicerJ's Avatar
just have the car on stands before doing it so you can just look under i know when i jack up my car that it doesnt always stay in the same spot
Old Dec 12, 2011 | 10:00 PM
ArmAnirx7's Avatar
Originally Posted by SlideAlliance
If you clean the living **** out of it and make sure its clean and dry you can put cardboard under the car then let it run and figure out where exactly the drops are
Benefits:
1. One will have a very clean engine bay
2. One will find the leak
3. One will hopefully fix the leak
Old Dec 13, 2011 | 04:37 PM
lftalbert's Avatar
OR Leaking oil
Definitely will, thanks.
Old Dec 13, 2011 | 05:08 PM
lftalbert's Avatar
OR leakage oil
sorry for double post. some mistake I made which made the post appear twice. I'll figure it out. thanks for patience. I'm learning.
Old Dec 14, 2011 | 10:51 AM
sHANE-DIZZLE's Avatar
I know, my picture sux
Mine leaks from everywhere, im not allowed to park in the driveway =[
Old Dec 14, 2011 | 10:56 AM
ArmAnirx7's Avatar
lol i am in your shoes my friend...
Old Dec 14, 2011 | 02:40 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Put a XL pizza box under it.
Eat the pizza first.
Enjoy!
Old Dec 14, 2011 | 04:03 PM
RicerJ's Avatar
honestly mine was leaking like a bitch from the oil cooler lines but i didnt see it until i was working on something under the car and followed it back to it now i have ss lines and i never have to worry about those lines again
Old Dec 14, 2011 | 08:27 PM
DriveFast7's Avatar
The aluminum AN fittings do wear out after repeated R&I where the hose end meets whatever it threads into (AN adapter to metric in our case)and the hose itself has a rubber liner which does deteriorate. The braid does chafe. Not bulletproof but I see your point.
The Goodrich brand of AN fittings is lower quality, cheaper and Made in CHINA! and I had to replace a set last year due to fitting wear. Would not hold a seal 100%. Since the individual fillings are each less than $50.00 they don't have to stamp Made by the Cheapest Method Possible Using Substandard Materials, as Quickly as Possible Without proper Quality Assurance. aka CHINA!
The real deal Earl's last much longer, now I know!
Old Dec 14, 2011 | 11:37 PM
RicerJ's Avatar
i have the corksport lines and i didnt need the an fittings
Old Dec 15, 2011 | 05:17 PM
dkwasherexd's Avatar
Garage Life
Oil Leak diagnostic
Come by my shop! We offer accurate oil leak diagnostic with uv light and engine dye. Il tell you EXACTLY where oil is leaking from in minutes, and give you an estimate for the repair at low prices!
Only $32.99 for oil leak diagnostic.
Garage Life LLC
11128 rush st.
South El Monte 91733
6264550415
Old Dec 15, 2011 | 05:25 PM
ArmAnirx7's Avatar
Garage Life LLC
11128 rush st.
6264550415
I am going to try to find it this weekend and if I don't I will come by your shop. Thanks bro
Old Dec 15, 2011 | 07:14 PM
lftalbert's Avatar
OR leaking Oil options
Turns out oil pan gasket needed to be replaced. thanks
Old Dec 15, 2011 | 07:17 PM
lftalbert's Avatar
thanks for info. It was oil pan gasket.
Old Dec 15, 2011 | 07:20 PM
lftalbert's Avatar
OR oil leakage
thanks
Old Dec 15, 2011 | 08:04 PM
lftalbert's Avatar
OR leaking oil
It turned out that it was oilpan gasket
