Microtech Error codes, hom ref rpm.. what to try first?
Old Dec 10, 2011 | 11:22 PM
Ruler_Mark's Avatar
I can't see my car **(
LT8 throwing Hom,Ref, and Rpm error codes everytime I hit 3k rpm also comes with some hesitation. Throttle position is irrelevant. Idles fine no codes till the 3k hesitation, checked the loom on the cas sensor and it is properly shielded. Time for a new sensor? Just looking for some advice to try to save time/money.
Old Dec 11, 2011 | 10:03 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the condition of the CAS plugs, and all associated wiring. Try swapping in a different CAS.
Often the wires crack comiing out of the connector and it's hard to see, until it fails.
Old Dec 11, 2011 | 12:45 PM
mattmarrx3's Avatar
isnt rpm got to do with the plugs?
Old Dec 11, 2011 | 01:48 PM
Ruler_Mark's Avatar
fresh 9s all around in it, could a coilpack be going to throw the rpm fault?
Old Dec 11, 2011 | 04:20 PM
RotaryEvolution's Avatar
Sharp Claws
or electrical noise, be sure the CAS loom is as far away from the alternator, ignition wires, coils and ignition amps as possible.
as mentioned check the wiring on the CAS and or swap it out with another. you can also try adjusting the air gap slightly down inside the CAS to get a better signal.
Old Dec 13, 2011 | 10:26 AM
TEDDER1's Avatar
I had to cut off my CAS plugs and hard wire it straight to them. The plugs were that bad. Never had a problem since.
Old Dec 14, 2011 | 06:14 PM
bumpstart's Avatar
talking head
3k hesitation is from having the staging algorithm or the stage point incorrect for the injector groupings
the home and ref error is the cas signals being corrupted,, the obvious is already stated, bad join at the wiring grommet on the cas
AND OR
noisy non resistive plug and lead combinations ( at least one or both need to be resistive )
excessive CAS air gap
cas wiring routed too close to ignition or to the alternator or E fan
sometimes the cure is easy
but sometimes you find you need to buy some shielded coax and rewire the CAS wiring , routing it the long way around to avoid the alt and ignition
be sure to make the shield tie to earth at the ecu plug end
Old Dec 15, 2011 | 01:08 PM
Ruler_Mark's Avatar
Staging fixed 90% of the hesitation, leading me to believe there is no tune on the car. Has a random hesitation and then throws the ref/hom/rpm codes at the same time, going to re-run the wire as stated thanks for the help so far!
Old Dec 15, 2011 | 01:31 PM
Gringo Grande's Avatar
1.5 Goodfella's Tall
Mark if you don't have an extra CAS....come talk to Daddy.
Old Dec 15, 2011 | 01:35 PM
Ruler_Mark's Avatar
*feels dirty*,, austin is going to rewire it tomorrow and we will see if it clears the codes if not sunday your CAS will be mine!
Old Jun 21, 2018 | 03:51 AM
Joel Toree Cady's Avatar
Hom ref rpm error mark_ruler
Ruler_mark did you figure out the problem I'm having the exact same problem with my fd has re routed the case wiring out new plugs on I'm out of ideas and getting a tune next week need a fix asap any help much appreciated cheers
Old Jun 21, 2018 | 03:52 AM
hey mate I replied on the forum you started having same issue was hoping you found a fix cheers ?
Old Jun 22, 2018 | 07:11 PM
abs351's Avatar
https://cimg9.ibsrv.net/gimg/www.rx7...daf9333753.jpg
Hi Joel,
did you inspect cas plug and wiring, usually such errors may also appear if stalling happens moving through gears or coming to a stop.
ultimately noise on the cas would do this.
I utilized a crow to view the cas signal for noise as I had issues too. I re-made my cas cable and grounded shields on both ends.
Old Apr 2, 2019 | 10:07 AM
Ruler_Mark's Avatar
Joel,
Replacing the Cas sensor wire with new shielded wire and grounding the the shield fixed this
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
ZacMan
Sep 19, 2015 09:20 PM
