1/4 mile times for a 12a get?
Old Jul 20, 2002 | 12:50 AM
Hyper4mance2k's Avatar
The Shadetree Project
What type of times could i expect from my rexy with bolt ons. right now its got a k&n, header, and exhaust. and hopefully tomarrow directfire. what type of times coud i get out of her with bolt ons and yes N02 is a bolt on no porting??
and i used the search and couldn't get the answers i was looking for....
Old Jul 20, 2002 | 01:01 AM
PaulFitzwarryne's Avatar
Apprentice Guru
Given a hp and weight there is no trouble in predicting a 1/4 time, with header/exhaust you would be low 16s, Without porting and lots of bolts you should get 15seconds plus or minus depending on your skills.
Going NO2 is a different matter, a rule of them is a well set up system will knock 3 seconds off your time. Unless of course you are using an old engine when your time will be infinity, it won't last the distance!!!
Old Jul 20, 2002 | 01:08 AM
Keaponlaffen's Avatar
I thought the RX-7 was a 16s car stock?
Jeff
Old Jul 20, 2002 | 01:14 AM
diabolical1's Avatar
i think it was "officially" about 17.4 seconds or something like that.
Old Jul 20, 2002 | 01:31 AM
hmmmm
ok
Jeff
Old Jul 20, 2002 | 01:33 AM
actually, that kinda sucks... my friend's 1986 Subaru GL had a faster 1/4 mile time than that stock.... now it doesn't... after 340,000kms, it's running on 2/4 cylinders, and when it backfires, it loses all power, and he has to re-start it after sitting for about 5 mins...
JEff
Old Jul 20, 2002 | 08:30 AM
Apprentice Guru
Stock 12a engined RX-7 has a 1/4 time of 17-17.4 seconds depending on the model, newer equalled slower due to weight.
Forum General Automotive has a sticky on performance data which lists the 1/4 time of practically every car sold in the USA over the past decade. Informative reading.
Old Jul 20, 2002 | 10:15 AM
Spieder's Avatar
Just outta curiousity, what speeds are you hitting at the 1/4? I have always looked at 0 to 60, and never wondered about the 1/4. I know stock 84 and 85 with 12 a is like 10.5 and 13b is like 8.5. Stock 83 and lower with 12a is like 8.5. (400 lb difference to account for)
Old Jul 20, 2002 | 06:33 PM
i'll let you know after tonight!
Old Jul 20, 2002 | 11:33 PM
Apprentice Guru
Stock 12a 17.2 secis hitting about 78 mph terminal
With headers the time is about 16.3 terminal 83 mph
With headers and mod carb 15.1 seconds and 90 mph
streetport the time will be about 14.2 sec and 96 mph
Go stock turbo 13.5 seconds and 100 mph
stock turbo and street port 13sec and 105 mph
going with the bigboys 11sec and125 mph
going with the big men 8 sec and 165 mph
Figures are an indication, everyone on the forum will say they can do better with a good launch!!
Old Jul 21, 2002 | 01:24 AM
my times
today i ran an few 16.7's i have a header, stock cat, and a straight trough dynomax muffler, k&n, and i did the direct fire MSD thing today!! rt's were .5-.7 and all my 60 foots were in the 2.4's oh yea trap speed was 82-84mph damnit thats slower than my old car and i sold it cause i thought the rx7 could be faster
what does everyone suggest i do next to the car??????
Old Jul 21, 2002 | 01:25 AM
Felix Wankel's Avatar
Super Newbie
Practice launching.
Old Jul 21, 2002 | 10:36 AM
crafoo's Avatar
2.4sec seems like a pretty high 60' time. what kind of tires? how are you launching it? Try to get that under 2sec if possible on your tires.
Old Jul 21, 2002 | 12:35 PM
jeremy's Avatar
male stripper
took the g-tech out last night. only got one run since i crunched 3rd on the first and had to change locations. my 1st real and only run gave me a 17.14@83.4. now remember its a g-tech so the mph will be higher then a track. i was running to high of rear tire pressure as i barked 3rd gear and i'm a stock 79 12a with sumitomos. the run was sans spare and jack but with a 98 lb passenger and at night so i had the airbrakes up. i figure a little adjustment on tire pressures, a little more seat time, and just me in the daytime, i should be able to hit 17 or possibly a high 16. still dissappointing after coming from a wrx and a 14.6 quarter.
Old Jul 21, 2002 | 01:11 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
I hit 15.7 @ 87mph with stock carb (other than unnecessary **** pulled off it and secondary spring cut down), emissions removal, RB short primary exhaust, e-fan, and 2 degree timing advance. My 60 foot times were usually in the 2.2-2.3 area. I haven't been to the track since my last major changes, but I'm anticipating much better times.
Old Jul 21, 2002 | 04:14 PM
peejay's Avatar
Old [Sch|F]ool
Now you're talking my kinda cars!
I doubt that it'd be faster though... less power and more weight! My GL took a solid 16-18 seconds to get up to 60.
Old Jul 21, 2002 | 04:55 PM
Apprentice Guru
Does anyone have any times when using NO2?
There are requent comments supporting using it, but what is the result?
Old Jul 21, 2002 | 05:00 PM
peejay's Avatar
Old [Sch|F]ool
That all depends on how much nitrous you use and when you set the system to start.
Someone who only gets on the bottle at the top of 3rd is going to have much different results than someone who starts spraying at the launch.
Old Jul 21, 2002 | 05:18 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Oh no somone said the S word
Old Aug 7, 2002 | 01:07 PM
onepointone's Avatar
i say what i want
what times do you think a 85 gs with a racing beat header, stock cat, and 2" straight pipe after that?
Old Aug 7, 2002 | 02:01 PM
Apprentice Guru
onepointone- my estimate would be around 16.5 seconds for the 1/4 mile, plus or minus .2 seconds depending on how well you launch and the general tune of the car.
Old Aug 7, 2002 | 11:05 PM
Newbie
well what about with an auto, are my times going to be slower than these listed?? they already are, i'm not sure what the cause is however, my 0-60 on the gtech is only 13 seconds and my quarter was 20 flat at 73mph...i noticed that my air filter needs changing, what difference would it make after i changed it?
Old Aug 10, 2002 | 12:38 AM
Apprentice Guru
An auto in good condition should get through the !/4 in 17.5-17.7 seconds. Any improvement to air filter, fuel filter, spark plugs will make you faster, but how much will depend on why bad it is now. 20 seconds is real slow so most likely you have a multitude of problems- but start with air, fuel, spark and prayers.
Old Aug 10, 2002 | 02:40 AM
Sweet cars, last forever, go anywhere
Only problem is that you can't put the jack in it, it falls through, the engine barely runs, etc, but it's still a great car.
But yeah, I read online that a stock, new Subaru GL from the 80's had around a 16.7-17.2 second quarter
Jeff
Old Aug 10, 2002 | 02:42 AM
peejay's Avatar
Old [Sch|F]ool
Must have been a 5-speed 2-wheel-drive 3-door with no air conditioning or power steering
