do you need the stock boost solenoid if you have a manual boost controller
Old Jul 19, 2002 | 04:51 PM
viperkiller7's Avatar
1.3 liters of whoop ass
i am piutting a manual boost controller on my 90- t2. do i use the factory boost solenoid or is it deleted. That is the only solenoid left in my car.
Old Jul 19, 2002 | 07:34 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no you just pull the van lines off the turbo and bypass it. mine's still there pluged into the harness though. just doesn't do anything. not sure if it'll turn on the check engine light or not with it unpluged
Old Jul 19, 2002 | 08:56 PM
Wankel7's Avatar
Haven't we ALL heard this
I unplugged mine and it made the check engine light come on.
I then left it plugged into the harness with no vacuum lines on it. However, the computer still knew it wasn't controling boost.
When I pulled the codes it came up. However, it did NOT make the check engine light come on. This is in my '91 TII.
James
Old Jul 19, 2002 | 09:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
hmm my vac lines are unpluged with no code.
Old Jul 19, 2002 | 09:09 PM
Wankel7's Avatar
Did you check it even though there was no check engine light visable with the ign. on?
James
Old Aug 23, 2002 | 04:15 PM
vmb
are you talking about a mnual boost controller or electronic ?
Old Aug 23, 2002 | 04:31 PM
DaleClark's Avatar
RX-7 Bad Ass
Few things here -
The stock boost control solenoid is good in one application - on a stock car. When you start modifying the car, it will quickly run away with the boost, giving you some dangerous overboost conditions.
The ECU doesn't care if it's plugged in or not - it will store a code, but will not flag a check engine light, and the car will not run odd or go into any failsafe mode.
Even if you don't have a boost controller, if you've opened up your intake/exhaust, disable that sucker.
Dale
Old Aug 23, 2002 | 04:36 PM
vmb
should you just tee the vacum lines going in or plug them?
Old Aug 23, 2002 | 04:41 PM
DaleClark's Avatar
RX-7 Bad Ass
One of the lines goes to the turbo inlet duct, and the other goes to the metal hardline on the turbo.
Easiest way is to pull the two lines from the boost controller and plug them. Best way is to plug the hole in the inlet duct and the one going to the wastegate actuator.
If you splice the two lines at the boost controller together, you're gonna have some serious boost.
Dale
Old Aug 23, 2002 | 05:30 PM
vmb
by plugging them will i see less or more boost or the same ?
Old Aug 24, 2002 | 10:06 AM
vmb
Old Aug 24, 2002 | 01:37 PM
Scott 89t2's Avatar
SOLD THE RX-7!
your boost will drop from 8psi to 5psi when you disabble it. but then it'll most likey creep higher.
the first thing I did was disabble mine before my exhaast went on. so I was getting 5psi slowly creeping to 9-10. adding a manual boost controler set to 9-10 made the car so much better
but don't use the stock one with a modded car. exspecially when using a FCD. ECU controls the stock boost controller. FCD makes the ECU see less then 8psi or so. so I bet the controller never fully cuts out causing more creep.
Old Aug 26, 2002 | 10:20 AM
vmb
what would happen if you disable without a boost controller?
Old Aug 26, 2002 | 11:58 AM
vmb
Old Aug 28, 2002 | 04:40 PM
vmb
please answer as what would happen if you disable without a boost controller
