Does the Greddy or HKS manifold work with an S366?
Old Nov 29, 2011 | 10:53 PM
2RotorsNaDream's Avatar
¿¿What are pistons??
I've been looking this up and couldn't find any straight answers. I want to know if I can run a Borg Warner S362 or S366 using a Greddy turbo manifold? Same with an HKS manifold. I've read that the S366 is a really tight fit with the Greddy manifold but that it does fit. I haven't heard anything about the HKS manifold.
Also, I'm looking for a max ~500-530whp with nice spool. I'm curious what you guys think, should i go with the smaller S362 or the bigger S366? I DD the car so I don't want to be maxing out the turbo to make that power. I want it to be a nice solid ~425whp for normal everyday driving but have the ability to make ~500whp when I want it. I have enough fuel, etc to run the turbo and the car to my knowledge is stock ports but alot of old school guys swear it sounds like it has a street port. We'll assume its stock port for this comparison. Thanks.
Old Nov 29, 2011 | 11:12 PM
For those kind of power goals you'll want the S366. A buddy has one (the 'XL' i think) and he made an honest 480 at 20 psi with pump gas and water/meth. Car flies down the road, very streetable powerband... he does have a nice streetport though.
I can't speak to the mani compatibility, sorry.
Old Nov 29, 2011 | 11:36 PM
C. Ludwig's Avatar
www.lms-efi.com
The HKS FD manifold will not work with the 366. It's very close but the turbo will hit the strut tower.
Old Nov 30, 2011 | 12:20 AM
rxspeed7's Avatar
F-IT
i know for a fact that the s360 fits a fc hks cast manifold. idk how much larger in size the housings are for a 366 are though but if may be a tight fit. this is in a fc also.
Old Nov 30, 2011 | 12:26 AM
I read about some guy here making 561 with the s362 at 23 psi with stock port motor. That sounds crazy. I will most likely end up with the s366 like you recommend regardless. Just interested in the s362 because of the slightly better spool, curious how much better it really is.
Thanks a lot, now I just need someone to chime in about the greddy manifold.
Old Nov 30, 2011 | 12:28 AM
I have an fd. Thank you anyway for taking time out to answer.
Old Nov 30, 2011 | 08:05 PM
C. Ludwig's Avatar
www.lms-efi.com
You know what, I was not thinking correctly when I posted the info above. We test fitted a 372, not 366. So, I have no idea if it will fit. Sorry.
Old Dec 2, 2011 | 09:27 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
I have a greddy T78 manifold with the S366. The only problem is the vband clamp. The turbo fits fine. But I had to trim a bit off the clamp itself to squeeze it by the LIM.
Old Dec 2, 2011 | 10:34 AM
Built Not Bought
Top Answer: 1
Adapted the Greddy kit's downpipe to work with the S366 (T78 uses a 4 bolt flange)
Pretty tight but it fits
You can kind of see about where I had to notch the side of the V-Band Clamp (not the vband flange itseft) to clear the front runner on the LIM. I trimmed off a 1/4" wide piece of material about 1" long. The clamp still had plenty of meat on it to do its job.
Old Dec 2, 2011 | 06:28 PM
That's what I was looking for, thanks a lot. At least that's one less thing to worry about.
The car looks like it's coming out good man, you think it'll be ready for next years meets?
Old Dec 4, 2011 | 02:55 PM
Built Not Bought
Top Answer: 1
It will be done prior to Deals Gap so I should be able to get to some meets next year. The only thing I probably won't be done with is the BBK, but that can wait until next winter.
Old Dec 4, 2011 | 06:03 PM
Anyone know about an HKS manifold that came with the T04Z kit? I have both the HKS and Greddy, if the HKS fits better I can use that.
Old Dec 18, 2011 | 09:56 AM
MOBEONER's Avatar
It's finally reliable
The greddy fits better
HKS is for babys, lol
Old Jan 15, 2012 | 07:18 PM
backroad-junkie's Avatar
Scotty Doesnt Know
bump for having the same dilemma
Old Jan 15, 2012 | 09:53 PM
Supraman522's Avatar
That is an interesting intake..Did you fab that yourself?
streetlegal?
Mar 17, 2022 02:46 PM
rotor_veux
46
Jun 12, 2018 10:39 AM
