Sponsored by: CARiD
Turbo Rx-8
Old Nov 27, 2011 | 03:13 AM
Rastocky's Avatar
Turbo Rx-8
Where does the turbo inlet oil line come from on the engine if you turbo an rx8
Is it the same as an FD turbo line feed?
Old Nov 27, 2011 | 09:14 AM
warren(silver-mazda)'s Avatar
RX-8 bewsts
It taps into the oil pressure sensor screw hole located at the base of the oil filter neck, utilizing a 'T' fitting
Old Nov 27, 2011 | 11:58 AM
RotaryEvolution's Avatar
Sharp Claws
or an oil filter sandwich plate, better than a brittle tee that can snap.
Old Nov 27, 2011 | 12:44 PM
lastphaseofthis's Avatar
My job is to blow **** up
I've tapped N/a irons on Fc's at the stock location, i wonder if one could do the same on the front Rene iron....
Old Nov 27, 2011 | 01:05 PM
Rastocky's Avatar
CT
Dude this helps out soooo much i have had that question for forever thanks
Old Nov 27, 2011 | 05:25 PM
vrx8's Avatar
Built not Bought
I used an oil filter sandwich plate on my turbo 8 no problems
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
