exhaust porting, dealing with the diffuser.
Old Jul 19, 2002 | 11:37 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
I want to build up a 89-91 13b for my first gen but I am worried about porting with the diffuser in the exhaust port. Is this hard to grind or torch out? Anyone done this?
Old Jul 19, 2002 | 12:29 PM
jimmyv13's Avatar
Round&Round not Up&Down
Just use TII housings, they don't have diffusers.
read this page........
http://www.mazdatrix.com/faq/6pexh.htm
Old Jul 19, 2002 | 01:53 PM
THats wher I learned of the problem. is that the common consensus on fixing it. I just dont want to spend the money on new rotor housings. If i can grind it out I will
Old Jul 19, 2002 | 02:02 PM
jimmyv13's Avatar
Yeah you can grind it out, but it will take forever and you'll go through a lot of bits. That thing is extremely hard steel.
Old Jul 19, 2002 | 04:31 PM
ajsuper7's Avatar
Nothin But a G Thang
what does the diffuser do exactly?
Old Jul 19, 2002 | 04:33 PM
SoloIIdrift's Avatar
You can try drilling out the side dowell pins that hold the diffuser in, use the search, I had my own personal battle with this and posted a lot of into on it.
Old Jul 19, 2002 | 04:51 PM
silverrotor's Avatar
I believe they serve two purposes. One Is to seperate, somewhat, the exhaust pulses of the outcoming exhaust, therefore muffling out the noise. Also, with the seperation In effect, It cools the exhaust stream that comes out by making It less concentrated by seperating It.
Old Jul 20, 2002 | 11:51 PM
is that why 2nd gens sound really deep insted of really chainsawish?
Old Jul 21, 2002 | 02:44 AM
rotarygod's Avatar
Rotors still spinning
Their main purpose is to help quiet the exhaust. That is also the reason for the shoebox of an exhaust manifold the n/a's have. The turbos didn't need them since the turbo itself helps muffle the engine somewhat. They also wanted the full exhaust energy to spin the turbo. 2nd gens can sound like a chainsaw or superbike. That is just the factory exhaust.
You can grind out those diffusers if you want to. They are made from unobtainium, a rather unknown supercompound from planet Krypton! Damn hard steel. Use a die grinder with a carbide bit (or several) not a dremel. Plan on a lot of time. It would be beneficial though since you can now enlarge the exhaust port. Good luck.
Fred
Old Jul 21, 2002 | 12:19 PM
I think I will try and port it and save money but if need be I think ill get the Turbo housings.
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
Engine stand ready
Aug 14, 2015 10:26 PM
