Video: RX7 FC bridgeport T04R dyno run
Old Nov 16, 2011 | 11:15 PM
Romanator's Avatar
QC Video: RX7 FC bridgeport T04R dyno run
My 89 RX7 FC bridgeport running 9.4 rotors, T04R, 2 Tial wastegates 38mm, 550cc and 1680cc injectors, Haltech E6X ecu, HKS exhaust, Making 326whp and 254wtq on 11psi @ 7500rpm.
http://www.youtube.com/watch?v=3038h3JNISU
Old Nov 17, 2011 | 08:25 AM
Len-Len's Avatar
Lenny
Definitely respectable numbers, but they seem a little bit low for that setup. Still I bet its a blast to drive. Dyno sheet?
Old Nov 17, 2011 | 11:49 AM
Romanator's Avatar
I will post dyno sheet sometime this weekend.
Old Nov 17, 2011 | 09:54 PM
ForsakenRX7's Avatar
zoom zoom go boom
I have to agree. Conservative tune?
Old Nov 18, 2011 | 09:02 AM
drifting in drifting's Avatar
Agreed. Look at my dyno i have alil smaller turbo and less aggressive porting you should be over 400
Old Nov 21, 2011 | 02:18 PM
funkjaw's Avatar
He's only running 11psi.. aren't you running 18psi?
Old Nov 21, 2011 | 11:44 PM
Ah I did not see that.Well i can say one thing that turbo will love 14+ psi its really just starting to come to life at 11 psi.
Crank it up with some w/i and 18 psi youll have nice numbers and with the bridge 7500 seems alil low after all the dyno is the stress test right?
Old Nov 22, 2011 | 10:01 AM
RotaryEvolution's Avatar
Sharp Claws
on top of that i really do not understand the point of bridging the motor to only tune it to 7500.
the last full bridge i built i tuned it to 9k and it still hadn't peaked out yet(would have had to remap everything to raise the RPM limit and the customer was fine with the numbers at 9k, 449whp).. of course it depends on the turbo but unless that is a T3 framed turbo with a .69 hotside you shouldn't be capped so low.
Old Nov 27, 2011 | 09:48 PM
Romanator's Avatar
Sorry the motor is an S4 half bridged with 9.4 rotors. And it's a T4 flanged T04R turbo with a 1.00 a/r hot side
Old Dec 12, 2011 | 12:27 PM
Sharp Claws
still bet you had more room to go with the half bridge. was the power level peaking yet?
Old Dec 12, 2011 | 11:51 PM
Carzy Driver's Avatar
Law Breaker
break in tune?
Old Dec 14, 2011 | 02:42 AM
hkp's Avatar
hkp
big turbo spoolin
is the motor pinned?
Old Dec 14, 2011 | 08:38 PM
Romanator's Avatar
Yes, I guess you could consider it a conservative/ break in tune. The turbo, transmission, diff, suspension need's a break in. I will be getting an email from the tunner with the graph and map file.
The motor is not pinned. It's an S4 block, HBP on top of large street port, 9.4:1 rotors, RA seals, mazda oem springs, FD oil system, FD stationary gears, e-shaft oil mods, Mazda Racing Pulleys, HKS clutch and flywheel.
Old Apr 29, 2012 | 07:54 PM
sharingan 19's Avatar
Rotary Revolutionary
Finally tap into the potential of that turbo/port setup?
Old May 5, 2012 | 07:14 AM
Cosmo_TT's Avatar
BRAAAAAP pssh BRAAAAAP
dont push it on pump gas
dkwasherexd
May 27, 2017 04:51 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Engine stand ready
Aug 14, 2015 10:26 PM
Turblown
Aug 14, 2015 04:48 PM
Clacor
Aug 14, 2015 09:17 AM
