who needs crown vic wheels when you can have these!
Old Nov 16, 2011 | 04:00 AM
lunardeathgod's Avatar
http://sanantonio.craigslist.org/pts/2622266179.html
Im going to pick these bad boys up and paint them gold. It should look awesome!!!
also, do crown vic wheels have a lower offset?
Old Nov 16, 2011 | 05:49 AM
monkey1911's Avatar
I happen to own a crown vic, so I can answer this question.
through 2002 all Crown vics and other panther platform vehicles ran low offset wheels, Ford redesigned the suspension for MY 2003+ and went to a higher offset. But I'm guessing that since those wheels are 15's that they are 1997 or older since 15's won't clear the dual piston front brakes on the 1998+'s. So that should make those wheels a low-ish offset, most likely can't tell because you can't see how deep in the lug nut holes go.
Old Nov 16, 2011 | 02:19 PM
_Mac_'s Avatar
True Winna
The stepped lip crown vics have an offset of 5-6ish. The single lips of course have less offset, I forget how much though.
Old Nov 16, 2011 | 02:20 PM
Steves13b's Avatar
Hiroshima Built
they look pretty good how they are. hopefully the offset is decent. post pics installed
Old Nov 17, 2011 | 04:11 AM
im sanding them down right now, im going to paint them gold.
Old Nov 17, 2011 | 09:58 PM
Here are the wheels I bought
sanding them down
and now I have primer and already wet sanded them. It was too cold to start painting, so hopefully tomorrow it would be warm enough to start painting!!!
Old Nov 18, 2011 | 02:29 AM
turboIIrotary's Avatar
Nice here was my fc with 16x8 bbs wheels form a lincoln gtc.
Old Nov 18, 2011 | 03:57 PM
Just a small update
Old Nov 18, 2011 | 05:51 PM
MacLuiz's Avatar
Came out pretty cleann, jus a little more lip.
Old Nov 18, 2011 | 05:56 PM
Well thats just the first coat, we added 2 more coats and im doing the clear coat now. Also there is still tape on the rim, so the chrome should pop out
Old Nov 18, 2011 | 07:00 PM
Finished! Just a little polish on the lip, and then im going to buy these center cap decals? and put them over the oldsmobile http://www.acromann.com/product_info...3}27{2}27{3}30
Old Nov 18, 2011 | 07:03 PM
Pele's Avatar
Right near Malloy
Weight and fitment compared to Mustang wheels?
Looking for a set of wheels to replace the Mustang wheels and R compounds that got jacked last month.
Old Nov 19, 2011 | 03:04 AM
Im not sure about the fitment yet, but i know they are pretty damn light. It might be around 18lbs- 20lbs?
Old Nov 19, 2011 | 03:54 AM
I have a question, the wheels are not glossy enough, after touching the painted area already, is it too late to apply more clear coat? I thought I put enough but i dont think i have. What should i do?
Old Nov 19, 2011 | 01:33 PM
mymmeryloss's Avatar
Oilfield Trash
Scuff, clean and reapply!
Look nice!
Old Nov 19, 2011 | 05:52 PM
Old Nov 19, 2011 | 08:12 PM
Also, im not sure if im being paranoid or not but, are the wheels in the front supposed to stick out this much?
It just seems weird that it sticks out that much. The wheels are the same size as the original wheels that came with the car. Is it possible that its just the alignment is off?
Old Nov 19, 2011 | 08:45 PM
Oilfield Trash
Same size, different offset...
Old Nov 20, 2011 | 07:46 PM
oh damn im retarded. I didnt think about it because the offset looked the same. Apparently it has a 8.9mm offset.
Old Nov 21, 2011 | 02:47 PM
funkjaw's Avatar
Rims look good!
Old Nov 21, 2011 | 03:43 PM
_Mac_'s Avatar
True Winna
I like how the fronts fit, good stuff right there.
Old Nov 22, 2011 | 12:12 AM
manimal(91vert)'s Avatar
Almost identical to vert wheels, but with better offsets. Looks good!
Old Nov 22, 2011 | 01:16 AM
hkp's Avatar
hkp
big turbo spoolin
youre over at cal and ing huh bro? i cant believe ive never seen that car before. wheels look good, keep it up man, maybe i will see ya out cruising. check out alamomotoring.com
Old Nov 22, 2011 | 01:35 AM
That's actually my cousins apartment, I live closer to babcock and huebner.
Old Nov 22, 2011 | 01:33 PM
funkjaw's Avatar
^ LOL you said ****.
