Power FC Weird problem with my "new" apexi.
Old Oct 25, 2011 | 10:53 AM
Flyvemyren's Avatar
Hey guys.
I just bought an used apexi FC power comamnder
But there is this weird problem.
It shows that i have 1.27 in boost before the car is even turned on. (ignition only)
But it works just fine on my friends rx7. Which is with a manual gearbox (mine is automatic) and it show 0.70 in boost and everything is in the best order.
Then we tried his apexi on my car, and THAT worked just fine.
How come there is a difference in those two? it got the same serial numbers (except for the last 4-5 digits of course) and they are both from japan.
Mine is an 1992 FD touring X with automatic gearbox.
And my frinds (the one we tried it on) is a 1992 with a manual gearbox
I really hope someone can tell me why
Also.
My friends apexi, dosen't show the RPM, in the dash (like it turns the needle off) what could cause that problem?
Old Oct 25, 2011 | 11:05 AM
Brodie121's Avatar
Does the pressure value change when the car is started?
if not check the map sensor.
Old Oct 25, 2011 | 11:34 AM
Flyvemyren's Avatar
I haven't started the car with my own apexi hooked up. I was scared to flood it
But it started just fine on my frinds, and there the pressure value did change.
And when i start my own car, with my friends apexi, the pressure value also changes.
Old Oct 25, 2011 | 01:38 PM
arghx's Avatar
rotorhead
There is some MAP-sensor related issue for sure.
Old Oct 25, 2011 | 01:59 PM
Banzai-Racing's Avatar
Rotary Specialists
Sounds like a ground/wire issue. The MAP sensor signal is maxed out, assuming you have the stock map sensor. For example if I unplug the stock map sensor the the PFC screen will read 1.12 kg/cm2. Take a look at the sensor check screen and see if there is anything else maxed out.
Do you have our Auto PFC adapter harness installed? If not you are going to run into shifting issues. http://banzai-racing.com/store/FD_auto_ecu_adapter.html
Old Oct 25, 2011 | 04:37 PM
Flyvemyren's Avatar
Okay then, stupid question, but MAP sensor? where is that located?
And how come my friends apexi dosent show any faults when we hook his up, to my car?
Old Oct 25, 2011 | 04:54 PM
Rotary Specialists
Map sensor is on the firewall, by the throttle body. Potentially you didn't have your plugs all the way in when you had your PFC installed. Put it back in, make sure all your connectors are seated properly and that you have not pulled any wires out.
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
