Worth re-using lower control arm?
Old Oct 25, 2011 | 09:08 AM
REAmemiya_fan's Avatar
Passion for Racing
Would it be worth pressing the old bearing out of the lower A-arm and installing an aftermarket one along with the bushings and re-installing them? All that vs. a new oem arm. Or at all. I would assume that a 22-year-old control arm would be a little sloppy...
Old Oct 25, 2011 | 09:32 AM
SpikeDerailed's Avatar
This sh*t burns oil!
Yes it is worth it, LCA's are expensive. Throw some engery suspension poly bushings in it and bolt on two new ball joints and enjoy.
Old Oct 25, 2011 | 12:23 PM
j9fd3s's Avatar
Community Builder
its not a BMW, on an S4 once you have the bushings and ball joints out, its just a piece of aluminum.
Old Oct 25, 2011 | 12:55 PM
3vil's Avatar
Mazda Misfit
consider this: a new front hub is like $500 (per side) and a lower control is about $500 (per side)
but you can do the bearings for about $60 (per side), ball joints can be found for about $30 (per side), and even a complete poly bushing kit for the whole car is just over $100.
it will be a bit more work to do the bearing/balljoints/bushing option, but it's a job you can do in a weekend if you're organized. i did this smae job last winter to my fc, plus i replaced the rear subframe mounts, all the rear diff mounts, eliminated the DTSS, and add a pinion snubber over the course of one weekend.
Old Oct 25, 2011 | 06:05 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Where are you guys finding cheap lower ball joints? They are $70 each on mazdatrix and not much cheaper elsewhere.
Old Oct 25, 2011 | 07:05 PM
user 893453465346's Avatar
Red Pill Dealer
No ****. S5's aren't replaceable.
Old Oct 26, 2011 | 01:00 AM
3vil's Avatar
Mazda Misfit
it's called google, you should try it
http://www.autopartswarehouse.com/sk...Front%2C+Lower
Old Oct 26, 2011 | 01:13 AM
esjoson1126's Avatar
TyrannosaurusRX7
Moog for $54 each on my local parts guy here in 91792. they normally run at 65-70 dollars.
Old Oct 26, 2011 | 02:46 AM
pyrod27's Avatar
Dreamer
rock auto for 60$
Old Oct 26, 2011 | 05:56 AM
beefhole's Avatar
interesting... I found the others for 54, 60 et cetera. Never saw one for 33
Old Oct 26, 2011 | 08:30 AM
DCRotor's Avatar
Got mine off of E-Gay(ebay) two for 40 shipped. I'm doing mine plus inner/outer tie rods this weekend
Old Oct 26, 2011 | 07:18 PM
TyrannosaurusRX7
autopartswarehouse.com brand is Mevotech for 34 dollars shipped.
Old Oct 26, 2011 | 08:17 PM
Derekcat's Avatar
Rotary Zealot!
Well... Airplane-style forged aluminum anyway.
Those A-arms are going to probably outlast the car..
fjwheeler
22
Jan 9, 2022 01:02 PM
GrossPolluter
Aug 15, 2015 10:32 PM
