Tranny ID help
Old Oct 18, 2011 | 12:02 PM
epic's Avatar
I
CA Tranny ID help
I am going to be looking at tranny for a 91fc sometime next week. How would I be able to tell that it will be for a 91 N/A engine and not a TII engine. Thanks.
Old Oct 18, 2011 | 12:04 PM
RotaryEvolution's Avatar
Sharp Claws
the TII tranny has a removable bellhousing, non turbos do not(bellhousing is part of the transmission).
the S5 has a V shaped mounting point for the transmission mount. S4 has a flat transmission mount pad on the bottom.
Old Oct 18, 2011 | 12:21 PM
j9fd3s's Avatar
Community Builder
the above and the turbo has a big flat removable cover on the bottom, the NA does not
Old Oct 18, 2011 | 12:29 PM
epic's Avatar
I
Sweet. I will try to find pics of this so I can get a better idea of what I am looking for. By any chance is there a part number engraved on the tranny that I can look for as well?
Old Oct 18, 2011 | 01:25 PM
Derekcat's Avatar
Rotary Zealot!
Also, you can use an S4 transmission as long as you get a crossmember and Y-bracket with it - they bolt up exactly the same and are usually cheaper..
Old Oct 18, 2011 | 01:45 PM
epic's Avatar
I
The crossmember is the one that kinda looks like a bone and is under the tranny on the front?
Old Oct 18, 2011 | 02:13 PM
87 t-66's Avatar
not a drifter
you would also need the Y bracket that mounts between the tranny and crossmember
Old Oct 18, 2011 | 02:14 PM
epic's Avatar
I
Sweet. Thanks.
Old Oct 24, 2011 | 07:12 PM
epic's Avatar
I
Picked up the trans and it fit perfectly to the engine, only problem. Is now tat it has the flat base mount. Anyone have the part number so i can order it from mazdatrix. Thanks.
Jetlag
Sep 29, 2015 06:52 AM
ricardo.benin
Sep 23, 2015 10:08 AM
