Transmission question.
Old Oct 15, 2011 | 08:44 PM
epic's Avatar
I
CA Transmission question.
I have a 91 FC N/A that will need a new tranny soon. I was wondering if TII trannys work for the N/A or will I just need to get a stock N/A tranny. Thanks.
Old Oct 15, 2011 | 08:52 PM
J5sense's Avatar
Can I install the Turbo II transmission into an NA?
Certainly. But you need to also install:
-TII flywheel, clutch, pressure plate
-TII slave cylinder
-TII starter
-TII driveshaft, differential, axels
-Adapt the wiring.
MazdaTrix makes a TII transmission to NA rear end driveshaft, so if you don't want to swap your rear end, you can use that shaft instead.
----from the FAQ's---------
Old Oct 15, 2011 | 09:12 PM
epic's Avatar
I
I see. Thanks for the info. By the sounds of it I will keep searching for N/A Tranny. Not much funds to swap out the whole thing.
MILOS7
Oct 9, 2015 02:19 AM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
rxlevi7
Sep 26, 2015 07:28 AM
