225/45/17 in front help
Old Oct 11, 2011 | 10:04 AM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
I was originally thinking to get 225/45/17 tires in the back and 215/45/17 in the front but then i realized when i would have to rotate the tires i would need 4 of the same so now I'm wondering if 225s in the front would cause anything to rub against when turning. Would I have a problem with that or will the fitment be fine?
Old Oct 11, 2011 | 10:43 AM
arghx's Avatar
rotorhead
Specs on the wheels? I am running 225/45/17
Old Oct 11, 2011 | 12:06 PM
sharingan 19's Avatar
Rotary Revolutionary
Good thing this hasn't been covered to DEATH in a 100+ pg thread on exactly this topic....
Old Oct 11, 2011 | 12:33 PM
RXSpeed16's Avatar
Theoretical Tinkerer
^While the FC "fit" thread is pretty comprehensive, it's a bit confusing to sift through. This exact question has come up twice in the last week here and here
In closing, Yes they can fit. If they fit depends on wheel width and offset.
Old Oct 11, 2011 | 12:44 PM
Kenshin XI's Avatar
S5 GXL NA - S5 TII
what specs are you looking for? all i know is that the tires are 225/45/17 and the rims are 17x7 - 4/5x100/114.3
Old Oct 11, 2011 | 01:05 PM
funkjaw's Avatar
I ahve 225/45/17 up front and they fit fine. Rim is 17x7 +30.
Old Oct 11, 2011 | 01:12 PM
RXSpeed16's Avatar
The wheel size is usually stamped in the inside of the wheel. Look for something like "17x7.5 et+45" means 7.5" wide and +45 offset. Check out the links stickied in the Wheels/Tires/Suspension section of the forum as well.
I run 225/45/17's on the wheels I used as an example above with a 5mm spacer.
Old Oct 11, 2011 | 07:00 PM
Rob XX 7's Avatar
FC guy
if its stockish offset it will fit no problem, 225/45/17 is a great size tire for the front of a FC
Old Oct 11, 2011 | 07:12 PM
bumpstart's Avatar
talking head
245/40/17 for me all around, no issue
Old Oct 11, 2011 | 10:38 PM
tom0261's Avatar
225/45/17 for me, too.
Old Oct 12, 2011 | 10:50 AM
TIIFC3S's Avatar
Freshly Built Streetport
I run 225/45/17 on 17x8 +35 all around with no issues. I regret not going 17x9 in the rear though.
Old Oct 12, 2011 | 01:39 PM
YaNi's Avatar
RIP Mark
Are you saying you are running 245's without rolled fenders and coilovers?
Old Oct 12, 2011 | 05:53 PM
bumpstart's Avatar
talking head
and not even spacers , in a late 85 / early 86 gxl narrow body ,, all in the offset
Old Oct 12, 2011 | 06:39 PM
MmSadda's Avatar
That setup works just fine for me on a 7" wheel with a +40 offset
Jutta_J
Mar 25, 2017 11:24 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
