Sub zero starting assist system vs winter
Old Oct 11, 2011 | 01:19 AM
NCharlebois's Avatar
Is the cold start system is necessary to start the engine below 16 celcius ? Mine is removed and I have to use my RX7 this winter...
Nic
Old Oct 11, 2011 | 01:47 AM
satch's Avatar
It doesn't work as designed.
Old Oct 11, 2011 | 04:09 PM
Osirus9's Avatar
Jackstand Drifter
no. The system isn't very good. My car will start in the winter just fine in Chicago and I have ALL of the cold start assist stuff removed (thermal pellet, coolant line through the TB, cold start cam, sub zero assist, even the BAC valve). It may not be quite as cold here as montreal, but it's close and you'll be fine
Old Oct 13, 2011 | 04:52 PM
Ok, thanks guys !
I'll need it to go to work at 6h45 in the morning, it'll have to start !!!
Nic
Old Oct 13, 2011 | 05:04 PM
RotaryEvolution's Avatar
Sharp Claws
block heater!
Old Oct 13, 2011 | 06:13 PM
3vil's Avatar
Mazda Misfit
heated garage?
Old Oct 14, 2011 | 06:18 AM
I don't have a garage and I don't recall having block heater...
Can I install a block heater ???
Nic
Old Oct 14, 2011 | 07:28 AM
texFCturboII's Avatar
version 2.0
I see oil fires in the future.
Old Oct 14, 2011 | 08:55 AM
Old Oct 14, 2011 | 09:55 AM
version 2.0
That was just an offhand comment about using an engine block heater around old, oil leaking rotary engines.
FYI, a block heater is simply an electrical device you plug in and attach to your engine block to heat it up. You don't necessarily "install" them, per se.
Old Oct 14, 2011 | 10:09 AM
Bruceman's Avatar
Rotor Power Rules
I've driven both the older 1st gen and the 2nd gen through the winter here in Michigan without the cold start system operational. So you will do fine as long as the battery is good and you're using a 5W-30 oil. Do not use a 20W-50 through winter
Old Oct 14, 2011 | 10:49 AM
Aaron Cake's Avatar
Engine, Not Motor
The system never really worked and Mazda issued a TSB for dealers to remove it.
Really, you're worried about the car not starting at 16C?! It's 13C out right now and I'm in short sleeves.
As long as there's nothing wrong with the car, it will fire up just fine regardless of temperature without the necessity for sub zero start systems, jumper cables, block heaters, etc.
Old Oct 14, 2011 | 12:58 PM
-16C...
It's the first and, I hope, the last time I have use it in winter... I'm a little nervous !!!
Nic
Old Oct 14, 2011 | 03:03 PM
phirzcol88's Avatar
phirzcol
2 first gens and current fc have all had no issues in mn. The first gen needed starter fluid one or twice to get it going, could have been flooded however.
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
