Brake pressure switch leaking
Old Oct 10, 2011 | 01:44 PM
rs1tc's Avatar
In the process of replacing the master cylinder on my 88 GXL, while bench bleeding the MC, I notice fluid leaking out around the pressure switch, so I replace the crush washer and go back to bleeding. Few seconds later fluid starts flowing out around the wires on the pressure switch. Called Mazda, they have nothing but a part number fb0743410 that is NLA. Local parts stores are at a loss. Dealer suggested I try the internet. Has anyone ever had this issue?
Old Oct 10, 2011 | 06:28 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
The switch for the ABS on the bottom you are referring to? Try some teflon tape on the threads.
Old Oct 10, 2011 | 07:18 PM
rs1tc's Avatar
Car doesn't have ABS.
Also, the fluid I thought was running out the bottom turned out to be coming from the brake fitting on the far side that I couldn't see. Cleaned it up and all is good now. Minus the caliper hardline threads being cross threaded . . .
Snoopy FD
Dec 8, 2015 01:45 PM
fastsaab
Aug 19, 2015 11:42 AM
