quicky on TPS adjustment (need answer asap)
Old Jul 17, 2002 | 08:43 PM
darkwaveboi's Avatar
Need donor car in Fairfax
I have a few simple questions. I saw the FSM and since i have an ohmometer ( i guess thats what its called) i thought i'd check to see if adjustment is needed;
(btw, idle is bad, but when i turn the ac on it evens out)
How do i get the harness from the TPS off without breaking it..its a weird one.
Do i test it w/ the keys in the ON position?
Do i test the part that touches the intake manifold, or coming from the wiring harness?
Should i set it so the resistance is in the middle of the FSM specs?
and finally;
The sensor above is the high and the one below is the low right?
Thanks
Jeff
Old Jul 17, 2002 | 10:04 PM
rxhevin's Avatar
Go to this link
Go to this link, there are pictures and instructions, also to remove the connection, pinch the coupler and pull:
http://fc3s-pro.com/TECH/HOWTO/TPS/tps.html
good luck jeff
Old Jul 17, 2002 | 10:29 PM
there are two on the NA models. One is black, orange and green, the other is yellow, red, and blue and goes into a 6 peg harness..thats why i got confused. but that site answered a lot of questions..thanks!
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
ZacMan
Sep 19, 2015 09:20 PM
