JB weld on the AFM broken nipple to avoid vacuum leak?
Old Jul 17, 2002 | 07:42 PM
Barwick's Avatar
SCCA Rookie
Do yous guys think that a dab of JB weld would be ok to use to seal up a boost leak on the AFM? The little nipple that sticks straight up is broken off on mine, and I'd kinda like to plug that up.
What would you suggest I do? JB weld or something else? Tape maybe? That's not gonna hold too well.. what should I do?
Old Jul 17, 2002 | 07:55 PM
HAILERS's Avatar
HAILERS
I don't think there is a nipple on the air flow meter. Is there a chance you meant the acv, the air control valve????
Old Jul 18, 2002 | 06:32 PM
Barwick's Avatar
SCCA Rookie
yeah my bad.. the ACV.. Should I JB Weld it up? Or what should I do to prevent this from spewing (and sucking) air?
Old Jul 18, 2002 | 09:26 PM
HAILERS's Avatar
HAILERS
The one that sticks straight up on the acv, on a turbo car, is to a diaphram. There should be nothing coming from this nipple. When everything is connected and working, there is a vac hose going TO it. That hose pulls a vacuum ON the nipple sticking straight up. So just put a dust cap on it or get a short piece of vac hose and put some rtv in one end, let it set up and put the other end on the nipple. If you insist on pluging it, I'd use a touch of rtv. Just a touch so you can ressurect it someday.
gabescanlon
Sep 5, 2015 12:04 AM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
