Is this engine cancer? or am I good to go
So, I pulled my motor because it was making angry noises and my tuner said the bearing was spun. There were copper shavings in the oil.
This is what I see when I took the front cover off. That rust isn't normal right? The motor was sitting on and off for months at a time, could that cause this?
These pics are of the oil pump on the new motor. Can I just clean that stuff off? it looks like surface rust...
Front counterweight on the new motor.
Also, I am switching front covers, which is why I took them off in the first place. I know the s4 and s5 covers are different, but they're interchangeable right? For some reason mine (s4) doesn't seem to want to fit on the new motor (which had an s5 cover, but I was told it was all s4)
Also, there was a bronze colored "guard" on the new motor's oil pump between the chain and the turbo oil drain line. it's just held on by 2 bolts and is super easy to remove. Do I need that? My engine didn't have one...
The "guard" that you speak of is an oil baffle I believe.
The rust is probably from the engine sitting for long periods. If there is moisture in the internals (like the oil and internal passageways) and the engine isn't warmed up to "boil" off the excess moisture, the internals could potentially rust like that. I would be skeptical of what the insides (Rotors, irons, e-shaft, etc.) look like though seeing the amount of surface rust on that counterweight.
Last edited by Aaron Cake; Oct 8, 2011 at 10:51 AM. Reason: Edit to remove misinformation
I know the front covers are different, that's why I'm switching them. But the difference is the turbo oil drain landing, and the OMP.
They can't be different as far as mounting to the front plate goes because they use the same gaskets... right?
S4 and S5 front covers are not interchangeable; they only mate with their respective front irons. The front cover oil passage is different between the two series of engines. S5 front cover oil passages have a nylon retainer around the rubber o-ring, S4 just has the o-ring.
the rust is from condensation from sitting and short drive trips, it could have been there for years. wire brush it off and forget it.
Karack, you're my hero.
Do I need the oil baffle that goes over the oil pump chain? it looks like it would block flow from the turbo oil drain...
Also, could that surface rust have flaked off and caused bearing damage?
Trending Topics
i've rebuilt many s4 turbo motors without the baffle as they usually go missing during previous rebuilds and not had any complaints.
rust pitting on the e-shaft could have caused the flaking, just inspect the shaft thoroughly for any pitting scars as they will cause aeration of the oil on the bearing and cause excessive wear in some spots. e-shafts are cheap so i wouldn't worry much about pitching it and finding a replacement.
i believe the chain cover is the reverse actually, it helps keep oil from slinging into the drain hole, blocking oil drain flow from the turbo. mazda was very thorough in making sure that the turbo drain was free flowing.
hmm i guess it could keep the chain from offending the turbo oil drain? since mazda deleted it, i'm going to say its hard to tell!
My apologies. I can't believe I said that, I don't know what I was thinking. I'll try not to post on such little sleep next time; I should've known better.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
