t2 maf interchange
Old Oct 4, 2011 | 10:09 PM
sodrifter's Avatar
www.discgolforegon.com
t2 maf interchange
do any other vehicles maf sensor's interchange with the rx7? i noticed that late 80s toyota pickups have the same looking maf.
Old Oct 4, 2011 | 10:21 PM
misterstyx69's Avatar
Retired Moderator, RIP
depends..some Supras can use the N/A AFM.Some dude bought one for that specific purpose.
if you have a S5 you may be able to change to a Cosmo AFM.(see ARGHX's thread, I think)
Old Oct 5, 2011 | 06:50 PM
n.taluckder's Avatar
theres a member i think k-tune with an 88 10th anne who runs a cosmo afm on a s4
Old Oct 5, 2011 | 09:35 PM
tuscanidream's Avatar
T2 Duo!
S4's have AFM's. S5's have MAF's.
Which sensor are we talking about here.
Old Oct 5, 2011 | 10:42 PM
Spirit-RE's Avatar
Why?
Get the maf/afm that is right for your car. They sell for like $50.
Not worth the potential issues.
Don't be that guy.
Old Oct 5, 2011 | 11:48 PM
ya,sorry it was K-Tune. Not ArghX.
Those Guys are on the Rtek Forum and I keep getting them mixed up,as they now alot of stuff!
Old Oct 5, 2011 | 11:57 PM
sharingan 19's Avatar
Rotary Revolutionary
No.
S4's have afm's.
S5's have afm's.
No rx7 ever came w/ a maf.....unfortunately
Also, the cosmo AFM (n390) will not idle (w/ 550 prairies at least) on an s4 ecu , or an rtek for that matter due to the fact that there is no idle adjustment capability. It will run , but it is too lean at idler and stalls.
Old Oct 6, 2011 | 12:16 AM
T2 Duo!
Originally Posted by sharingan 19
No.
S4's have afm's.
S5's have afm's.
Now I'm confused.
Here's what I found under Airflow Meter Sensor on wikiwikipedia:
The vane (flap) type air flow meters (Bosch L-Jetronic and early Motronic EFI systems or Hitachi) actually measure air volume, whereas the later "hot wire" and "hot film" air mass meters measure speed of air flow.
So isn't the "hot wire" a mass airflow sensor and not an airflow meter?
S4
S5
Old Oct 6, 2011 | 12:38 AM
And there isn't a "hot wire" in either one of those units. Don't let the shape fool you, the s5 is merely a cone-style AFM as opposed to a flapper door style.
Old Oct 6, 2011 | 01:04 AM
T2 Duo!
Gotcha. How does it work?
Old Oct 6, 2011 | 01:17 AM
Arghx has a thread on here w/ airflow #s between the different AFMs, it also has cutaway views of their operation and technical papers on the subject. I would link it, but I'm on my phone and that's too much work.
Short story: there is a cone in a tube, that cone has a spring (of a known resistance) behind it such that the further the cone is pushed into the tube, the greater the volume of air is registered. ....far from a maf, but still better than the s4 crap meter.
Old Oct 6, 2011 | 01:27 AM
nycgps's Avatar
PedoBear
Just look at the throttle cable, and think of the cable is the "incoming air/force", it pull(push) the clip that's attached to a spring.
the AFM works almost the same way.
Old Oct 6, 2011 | 05:28 AM
T2 Duo!
Thanks for the explanation! ...and sorry for the mis-information I gave.
Old Oct 6, 2011 | 06:33 PM
sodrifter's Avatar
in not gonna be that guy to use the wrong one. i was just curious after seeing my buddys toyota afm
Old Oct 6, 2011 | 06:44 PM
The FC afm is unfortunately the crem de la crem, of antiquated air metering technology.
Lots of other cars can see gains by swapping in an fc afm (supra, mr2, miata etc) but most any vehicle w/ real performance potential had already ditched the afm by the time the fc came along.
Wicked93gs
42
Oct 7, 2015 11:58 PM
