Stupid strut question :facepalm:
Old Oct 3, 2011 | 04:53 PM
MmSadda's Avatar
Does a 2nd gen have struts both front and rear?
I hate to admit it, but I don't actually know what constitutes a strut.
Old Oct 3, 2011 | 04:59 PM
RotaryEvolution's Avatar
Sharp Claws
yes they do.
a mcpherson strut is a shock absorber that has a spring perch and spring integrated into the shock itself.
Old Oct 3, 2011 | 05:14 PM
MmSadda's Avatar
Originally Posted by Karack
yes they do.
Awesome! Thanks for the proper explanation - I was having trouble finding one that made sense online.
Looks like it's really easy to remove the struts on these cars, no spring compressor needed, right?
Old Oct 3, 2011 | 05:16 PM
Sharp Claws
you only need a spring compressor if you plan to replace either the spring or the shocks. no compressor needed to pull the strut out of the car, no.
Old Oct 3, 2011 | 11:54 PM
Derekcat's Avatar
Rotary Zealot!
and if you can push down enough[and have a friend nearby to put the nut on] you don't even need the compressors to put the stock spring back on.. RB [1" drop] springs don't even need you to compress it to get it back together..
Though, be careful. ^_^
Old Oct 4, 2011 | 05:52 PM
Osirus9's Avatar
Jackstand Drifter
^^ That's a strut in Derekcat's sig
(The thing with the red spring on it)
Old Oct 4, 2011 | 10:38 PM
DeaconBlue's Avatar
Living on the North Coast
Yes McPherson strut up front with Chapman strut in the rear. Both have concentric mounted springs. The difference between the two designs is the the McPherson also acts as the upper control arm in the front suspension.
See the attached photos.
Attached Thumbnails Stupid strut question :facepalm:-dcp_1754.jpg   Stupid strut question :facepalm:-dcp_1818.jpg
Old Oct 5, 2011 | 08:32 AM
Travis R's Avatar
trying to build a racecar
Uh, it absolutely does NOT have a Chapman strut in the rear.
It's called a strut when it takes side loads, and it necessary to "locate" the wheel. The rear suspension on an FC is a semi trailing arm. Front is a MacPherson strut.
http://en.wikipedia.org/wiki/Chapman_strut
Old Oct 5, 2011 | 10:20 AM
DeaconBlue's Avatar
You are correct, I was confusing it with the rear strut on the S30 Datsun cars (240Z-280Z).
13
Jan 9, 2018 11:19 AM
msilvia
15
Sep 11, 2015 12:13 PM
