Need help with sunroof
Old Oct 1, 2011 | 12:44 PM
airman90's Avatar
Angry Need help with sunroof
Hey guys im having an issue with my fc sunroof. the motor works but the sunroof wont open. i've tried pushing it up but no luck. i dont know what the problem might be. any ideas?
Old Oct 1, 2011 | 04:11 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
the gears on the motor could be stripped, the cables could be stuck. The sunroof really is a tremendous pain and you'll only find out the hard way!
Old Oct 1, 2011 | 04:32 PM
J5sense's Avatar
the sunroof system is quite simple once you have it all apart. compared to new cars at least. it has 2 cables ran by the motor. drop your headliner and unbolt the motor. see if the gears are stripped. most likely your cables are sized in the tubes. mine where at least. best bet is to find a sunroof assembly on the forums or junkyard. the cables are about 120 each from mazda if you can get them out of the tubes.
i had my left one locked up and was able to get a tube from the classifieds and purchased a cable from mazda. i have a working sunroof but i shoud have got both cables as they strech with age. mine creeks a bit but it works.
Old Oct 1, 2011 | 10:26 PM
airman90's Avatar
I am paint it next month im thinking about eliminating it.
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
